Radiator holding back Drag install =/
The whole cooling system in my car has been fucked due to the previous owner .. Radiator leaks, hoses were full of corrosion, been flushing it out 2-3x a week.. Put a hose on one side and literally orange water was coming out of the other end.. did that a couple times, did a complete flush... put some more distilled water.. Saw it leaking today.. probably cracked or some ****, sick of it!
Just going to buy a new radiator, I don't really want to go fancy.. what stock radiator for a 95 Teg will not need any modifications to clear a Drag kit What aftermarket radiator (Fluidyne, PWR, etc) can I buy that won't need modifications either..
Radiator is holding back my turbo install.. need to fix this quick, help!
[Modified by deception23, 8:35 PM 9/12/2002]
Re: Radiator holding back Drag install =/ (deception23)
Re: Radiator holding back Drag install =/ (LudEcrous)
will the fans clear... I don't wanna buy a 400 dollar radiator to have to modify fans or buy new ones ;(
there was another member on here who just got his C&R radiator in his teg.
Check out his post.
https://honda-tech.com/zerothread?id=277791
Comes with one fan too. I will most likely get it from the GB too. I was just wondering what happens when you turn on yer AC since it only has 1 fan.
Check out his post.
Re: Radiator holding back Drag install =/ (Turbo E)
um i just had pwr make me a cusotm sized radiator for 400.to my own specs.you can alwyas get spal fans.they are about 100 bux but they are onyl 1 inch thick.
buy your cheapo rad then get a Flex-a-Lite fan. they're 1/2 the thickness of stock.
1 Post
Re: Radiator holding back Drag install =/ (01geeser)
flexalite fans are still pretty thick. go with kragen 12" fans, they are thinner and cost less.
I also wouldnt be doing a coolant flush all your doing is loosening up crap and amke ur engine suck up all that debri.....
