Radiator fan wont fit! FAL? 1 or 2?
After my turbo install the radiator fan doesnt fit. So I understand I am suppose to use a pusher fan from the other side. Is FAL the only brand and where do I get one from? Also how big is recommended? Is 2 smaller better than 1 bigger? Do I need one Integra specific? Sorry for all the questions but I really want to finish this right! Thanks!!!!!!!!!!!
Re: Radiator fan wont fit! FAL? 1 or 2? (RedTegLS)
you can get the fal's or autozne sells some universal pusher fans for like $60
they are around 850 cfm for the 12" if i remember correctly.
these attach with zip straps.
Re: Radiator fan wont fit! FAL? 1 or 2? (Foozball26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 »</TD></TR><TR><TD CLASS="quote">these attach with zip straps.</TD></TR></TABLE>
Where do you find these fan zip straps at? I've looked around the local auto stores and the employee's are dumbfounded when i tell them exactly what I need.
Re: Radiator fan wont fit! FAL? 1 or 2? (GudeH23a)
Tell them you need an install kit for a trans cooler, they are the same ties. If you still have a problem call Summit or jegs they should have what you need. The kits are cheap though so you would probably pay more for shipping LOL.
Re: Radiator fan wont fit! FAL? 1 or 2? (DSMkarz)
the straps come with the imperial fans you get at autozone.
you can always use zippie ties and small plastic washers to hold it onto the radiator.
Re: Radiator fan wont fit! FAL? 1 or 2? (Muckman)
I"m using Spal in my 355 V8 Porsche 997, I had used summit racing brand in my 327 V8 Porsche 914. I like them all. Just look for the flow rate. Most of the aftermarket fans are thin.IMO, 2 are always better than one if the radiator have room for 2.
6mtcoupe
10-18-2005 05:10 AM
