Racepak's ***SOHC BUILD*** D16 What?
Hi guys,
so i spun some bearings a few month ago on my old vitara d16 and decided to get a new engine and go at it again,
new setup:
d16 stock sleeves
vitara 75.5
eagle rods
arp studs
oem head gasket
new oem ported oil pump
moroso 5.5l oil pan and larger pickup
ported z6 head
bisimoto 3.6 cam
bisimoto pro springs and titanum reteiners
supertech flat valves
venom intake manifold
miniram manifold + tial 38
garrett t3/4 57 trim (soon to be replaced with a 3076)
3" exhaust
treadstone tr10 intercooler
Motec m4 ems
AEM EPM
AEM TWIN FIRE
AEM COILS
fuel injector clinic 850cc injectors
S40 B00
OBX LSD
ACTION MS2 CLUTCH
TOYO R888
this was the old setup:
THE CAR:
had to do some mods to fit the bisimoto 3.6 cam
ports:
before finishing:
valve train:
wrinkled valve cover:
this stuff works amazing!!!
intake:
i like:
manifold
moroso vs oem
DONE, just need to degree the cam
painted the engine bay while waiting for tommorow
new setup:
d16 stock sleeves
vitara 75.5
eagle rods
arp studs
oem head gasket
ported z6 head
bisimoto 3.6 cam
3" exhaust
Motec m4 ems
AEM EPM
AEM TWIN FIRE
AEM COILS
S40 B00
OBX LSD
ACTION MS2 CLUTCH
TOYO R888
THE CAR:
ports:
before finishing:
valve train:
intake:
i like:
manifold
moroso vs oem
Re: Racepak's ***SOHC BUILD*** D16 What?
Hey what bearings are you running? I'm building a setup very similar to yours but my rod bearings clearances are really tight. What were your clearances on rods with the eagles?
thanks guys,
i didnt micropolished the cranck, the engine is basicly new,
i didnt used fjt rods since i didnt knew my piston to valve clearance until i had the bisimoto cam,
forgot to update
sry
some pics of the lsd install from the last project
the motec m4 to obd1 adaper it fits in a oem case
break in additive
the oil i used:
external iacv:
had to make some fittings for the fuel feed line:
oil pan clearance:
DONE
sry
break in additive
the oil i used:
external iacv:
oil pan clearance:
DONE
i had to cut the some of the rocker arms since they hit the spacers on the intake side rocker arms,
and i also had to remove some of the casting in the cam oil pools,
very clean setup. looks good. cant wait to get my turbo setup going soon. if it looks half as clean as that id be happy with it lol. im feelin the oil pan. i def want to pick one of those up.
i'm doing the break in with oem ecu and injectors, i will swap to the cop when after ill finis the 1000 miles,
13g, do you have the 3.6? whoch head casting are you using? p08?
Yes. 3.6 in stock z6 head. If its hitting, I can't tell. I do think though that I have a LMA going down. Was yours physically hitting?
mntdewred
10-14-2002 06:41 PM
