Quick Head Gasket Question
I need some quick help since my head is going back together today.
For my LS non vtech on 11 pounds with je pistons, eagle rods, arp headstuds, what kind of HG should I use? Stock or ML HG? also, what thickness do you guys recommend for the HG? |
Re: Quick Head Gasket Question (PBsTREETracer)
Stock is the best you can use.
STOCK and stock is ML is assume you mean multi-layer by that
Re: Quick Head Gasket Question (turbotypeR@SPEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR@SPEC »</TD></TR><TR><TD CLASS="quote">Stock is the best you can use. </TD></TR></TABLE>
IMO 2:thumbup: |
Thanks, that was some quick replies.
yea i mean multi-layer. also, what thickness should I get the stock HG in? |
Re: (PBsTREETracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PBsTREETracer »</TD></TR><TR><TD CLASS="quote">Thanks, that was some quick replies.
yea i mean multi-layer. also, what thickness should I get the stock HG in?</TD></TR></TABLE> oem gaskets only have one thickness |
Re: (PBsTREETracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">
oem gaskets only have one thickness </TD></TR></TABLE> just use the dealer gasket for your car |
My brother just went to the dealership to pick up all oem gaksets for everything.
He also is suppose to get some RP tranny fluid and RP 15-40. |
Re: (bimmeracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bimmeracer »</TD></TR><TR><TD CLASS="quote">My brother just went to the dealership to pick up all oem gaksets for everything.
He also is suppose to get some RP tranny fluid and RP 15-40.</TD></TR></TABLE> wow...... thats cool? |
Re: (agrn93ls)
OK.
If you dont know the OP is my brother. |
Re: (bimmeracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls »</TD></TR><TR><TD CLASS="quote">
wow...... thats cool?</TD></TR></TABLE> OK. If you dont know the OP is my brother. |
want a cookie?
i hVE Hd good success with the felpro mls there only 45 a pop.
when i cracked a sleeve the fel pro looked perfect. |
