Question about turbo systems (Still a noob!!!)
Hay every one, i was just wondering if there was anything out there that at the flick of a switch, turn off a turbo system or change it from a low psi to a higher psi, so you could run hard only when you needed to?
Re: Question about turbo systems (ekboi2008)
there is nothing with a flick of switch thats going to alow you to completely turn off the turbo kit so to speak....there is something called a boost controller that alows you switch from high to low boost settings though
