Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   Pros and Cons of test pipe? (https://honda-tech.com/forums/forced-induction-16/pros-cons-test-pipe-410213/)
greddyturboGSR Feb 8, 2003 02:05 PM
Ive been hearing things both good and bad about running a test pipe. Is it worth the hp gains? Where is the best place to get one made? Also, I live in Cali so what kind of fines am I looking at if I get caught without a cat? pics welcome
thanx
greddyturboGSR Feb 8, 2003 02:23 PM
Re: Pros and Cons of test pipe? (greddyturboGSR)
anyone have experience with a bad odor due to the lack of a cat. converter?
greddyturboGSR Feb 8, 2003 03:36 PM
anyone??
blufke Feb 8, 2003 03:38 PM
you will smell it.
AB16A2T Feb 8, 2003 03:40 PM
Pros: Small Power Gains over Cat, unless you are running high boost and then it's even larger gains
Cons: Smells
Big fat TICKET depending on where you live, IE Cali = $5000 ticket I believe.
Polluting the environment.
Evil EG Feb 8, 2003 03:45 PM
Re: Pros and Cons of test pipe? (AresB16A2Turbo)
Pro - More Power
Cons - OBD2 = Check engine light, fail smog tests
greddyturboGSR Feb 8, 2003 03:45 PM
thanx guys, I think I will deal with the loss in hp to avoid the fines and odor. Atleast I could always tell my girl it wasn't me stinkin! https://honda-tech.com/forums/images/smilies/emwink.gif
greddyturboGSR Feb 8, 2003 03:47 PM
If the check light and failing smog were the only cons then I would go for it. Im interested in how bad the fine would be.
blkDOHCsol Feb 8, 2003 03:50 PM
when you hug your girlfriend when you get to her house..she will tell you that you smell like gas...
zip Feb 8, 2003 03:51 PM
Testpipe http://a3.cpimg.com/image/83/F3/1344...-014000F0-.jpg
tuning
http://a7.cpimg.com/image/C3/1F/1431...-014000F0-.jpg
= no smell, no CEL, and a lot of https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images/smilies/embeer.gif
JDMs1eeper Feb 8, 2003 03:58 PM
Test Pipe helps a lot. it dont smell on my car either... get one that bolts up so you can put you stock cat on when you get your smog test (i live in VA w/o smog tests https://honda-tech.com/forums/images...es/emsmile.gif )
98AccordEX Feb 8, 2003 03:59 PM
Re: Pros and Cons of test pipe? (zip)
zip - do you sell the o2 simulators? or is that just a link to someone elses site?
greddyturboGSR Feb 8, 2003 04:03 PM
Re: Pros and Cons of test pipe? (98AccordEX)
but does anyone knwo what the fines are like?? I was thinking It would be more along the lines of a fix-a-ticket. But ive been hearing 4 digit numbers here!
boostedsol Feb 8, 2003 05:07 PM
I just got a testpipe. Reason being is that I would still fail emissions, so why not get a little bit more power out of it all? That's what I did, but it will still smell like gas regardless if you have a cat or a test pipe.
I dont know how strict the laws are where you are at, but in TX all you have to do is take it to a shop and pay them off w/ some $$ for your emissions sticker.
