PRONLEM WITH WRIST PIN
PROBLEM WITH WRIST PIN
What kind of noise would a wrist pin sound like if it was bad. I have a weird sound from the block and I know it's not my rod because It doesn't get louder and while driving you cant really hear only when im at idle. AND NO ITS NOT MY VALVES I DID A REVERSE COMPRESION TEST.
i dont really think it would be the wrist pin, it could possibly the the bushing on the rod that the wrist pin slides through. if that has got out of round, or if the wrist pin is damaged then you will get like a slight knocking sound. i had that problem, and i thought it was just piston slap. but i wanted to be sure so i got bored and took the motor apart, found that i could shake one of the wrist pins in the rod, so i had that bushin replaced and there was no sounds after that.
