Problem with fast-turbo oil line kit....
the silver adapter that goes into the block where the stock oil pressure sensor goes does not seem to fit, it won't even thread into the block, the stock pressure sensor threads in fine. It seems like I received the fitting damaged or the threads aren't sharp or something they seem like they're flat....anyone else have this problem?
Re: Problem with fast-turbo oil line kit.... (boostismycrack)
because they're closed and i've been trying to figure out why it won't thread into the block....when the stock oil pressure sensor threads in fine but the fitting doesn't...https://honda-tech.com/zerothread?id=1551152 there is the link to the picture, it's the first picture on the page and it's the silver fitting.
Re: Problem with fast-turbo oil line kit.... (93c1sol)
I had the some situation with the bspt/npt adapter. I happened to have two which I had previously ordered for my firewall kit. The one that came with the kit just did not want to thread in at all. I did not bother stan for it since the part is like 3-4 bucks, and he had helped me enough. I ordered my stuff from http://www.mcmaster.com and the part number is 4092k81 (I believe). The fittings threaded right in. You can also call stan and let him know as he is very helpfull.
wrenchin'
1 Post
Re: Problem with fast-turbo oil line kit.... (drintegra)
i had the same problem with their kit. weird thing was, the adapter WOULD NOT thread into my B16 block, but went right into my LS block. same adapter. weird
ive had a similar problem but with a differnt kit. went into my z6 block fine, but not my ls. bought the exact same oil line kit again afor the new setup and it went in like butter. ive thought about it long and hard b4, but figured to hell with it since the new kit fits anyways
Re: (raiden571)
Hey Guys,
To those of you that have the problem, I need your favor...
If you can send the fitting back to us. I'll pay for the shipping back. I'd like to examine them one by one to see if there's any change in thread pattern.
Some things that you may be able to do to prevent this from happening again.
First off, make you clean the threaded hole thoroughly. Honda uses honda bond to seal the stock oil pressure sender and I have seen some threads is compeltely covered in it and therefore it prevents any new adapter to threads in. This is how some of you can fit it in 1 block and not the other.
Either case, send it back to me and I'd take a look at it to make sure we will never have this problem again.
Thanks Again,
PS:
Steven, your fitting is going out today...good luck..
Thanks Again,
PS:
Re: (LS-N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-N »</TD></TR><TR><TD CLASS="quote">^^^ Great customer service, thanks again.</TD></TR></TABLE>
We try....I know things get overwhelmed at times...and I am not the guy with the best memory.
If I can help, I will...if it's my products, I'll back it up 100%..
stan
stan
Re: (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">stan the man. i cant send you mine back because its IN my LS block right now running mint, no leaks, working wonderful</TD></TR></TABLE>
ooh okay, don't send it then lol
Re: (Flamenco-T)
Thanks Stan, I appreciate the help and fast shipping! Do all the fittings work for every block? I have a GSR block..didn't know if that matters or not
Location: The Village Hidden in the Leaves: Seattle, WA
it doesn't matter, they're all the same.
i thought at first maybe you were tryin to put the oil restrictor in the back of the block cause that's the only silver fitting i got when i ordered my oil lines from stan...
stealthmode62
10-03-2011 06:14 AM
Nordy
11-24-2006 09:07 PM
