pressurize the fuel rail from both sides??? What are the advantages??
1 Post
I´ve heard from some people that they pressurize their fuel rail from both sides. I´m wondering what are the advantages oder disadvantiges of this setup. And I´m also interested in how it looks like and how it works. Where are the lines are connected to. Any ideas????
Re: pressurize the fuel rail from both sides??? What are the advantages?? (hovic)
If you measure egt's after going to a dual feed rail they seem to be more consitant across the board. Better power balance and now you aren't tuning for the leanest cylinder rendering the other 3 a little richer than desired. 4 cylinders working together better= more hp.
Modified by Wideopentuning at 8:53 PM 4/12/2005
Re: (servion)
Since fuel is a liquid the pressure will be equal across the entire fuel rail as long as cavitation does not occur. (Fuel injectors do not pump fuel) I think the real point is to provide more flow for higher consumption requirements.
1 Post
Re: (Wideopentuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wideopentuning »</TD></TR><TR><TD CLASS="quote">The return will be taken out of the middle of the rail or back at the remote mounted regulator.</TD></TR></TABLE>
Some pics please :-)
Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">Since fuel is a liquid the pressure will be equal across the entire fuel rail as long as cavitation does not occur. (Fuel injectors do not pump fuel) I think the real point is to provide more flow for higher consumption requirements.</TD></TR></TABLE>We use TWO fuel rails with 8 1600cc injectors. The fuel goes in the upper rail, fills it and then goes to the second rail and then out of the second rail to the return with no problems. As long as you use a pump with enough volume, it doesn't matter where the fuel comes from.
tnbigdawg
09-24-2003 11:30 AM
