PR4 ecu for Hondata S300 installing a vtec driver????
Re: PR4 ecu for Hondata S300 installing a vtec driver???? (JDMCRX)
yes. its the same method as a P06 ecu i believe. u need the 515 switch, 1n004 diode, 2361 transistor, 1K resistor, jumper wire (i dont put in the capacitors, never made a difference with it in or out)
Mr. Badwrench
Re: PR4 ecu for Hondata S300 installing a vtec driver???? (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">You can use a different output on your ecu so you don't have to add hardware to it.
Go to help, contents, search, vtec parameters. </TD></TR></TABLE>
yup all you need to do is relay the out put to the vtec solenoid.
Mr. Badwrench
the outout cant handle the current draw. thats why you need to relay it. (thats what i remember from reading) still looking for the write up.
Mr. Badwrench
if you open up a map or cal in the s manager, > parameters > vtec > vtec output for non vtec ecu's it says there you need to use a relay. relaying usually means using a low current circuit to control a high current circuit.
it is easy as using a bosch style 5 pin relay.
