what is the power capability for a stock engine B18A/B that is turbocharged?
Old 05-31-2019, 05:02 PM
purposebuilt's Avatar
Default what is the power capability for a stock engine B18A/B that is turbocharged?
Hi I was just woundering what would be the max you could boost on a stock sleeve b18 non vtec if it had forged 0istons and shott pined rods with arp rod bolt. And how much the max boost would be on a stock sleeve b18 wit h beam rods and forged pistons on a daily driven e85 tuned car
purposebuilt is offline
Old 05-31-2019, 05:38 PM
Chance EG's Avatar
Default re: what is the power capability for a stock engine B18A/B that is turbocharged?
Most people consider around 400WHP on stock sleeves to be the point of diminishing returns and exponential risk with the OEM B sleeves.
With a stock non-VTEC head I'm not sure what your numbers will end up looking like. Don't get a huge turbo.
Boost pressure is irrelevant to the engine holding the power or not. 10PSI on a GT28 is not the same as 10PSI on a 6266.
Chance EG is offline
Old 05-31-2019, 05:58 PM
K7-1Ktrevor's Avatar
300-350whp for stock Rods, the rods would be my biggest worry especially with how much torque a turbo ls makes at the 350whp mark.
K7-1Ktrevor is offline
Old 05-31-2019, 06:23 PM
Premium Member
Aradin's Avatar
^^ Agreed. Stock rods will blow before the sleeves. Even shot peened with ARP bolts. Shot peening doesn't add any strength to the material anyway.
With aftermarket H beams, it's gonna be a mixed bag beyond 400whp as was already said. Some get lucky and can push farther, some don't.
Aradin is online now
Old 05-31-2019, 07:15 PM
turbociv910's Avatar
330 whp be fun, run 12s and last for ever..
turbociv910 is offline
Old 06-01-2019, 11:09 AM
Balor_Gr's Avatar
Considering LS has both worse Rod stroke ratio and rod width id say dont go over 8.000 rpm and get a turbo on the big side. Early torque hit with a GT3071 will be hell compared to the same hp target with a GT35.Off course your trading drivability and fun with reliability...
Balor_Gr is offline
Old 06-01-2019, 11:28 AM
Chance EG's Avatar
Derp, forgot he's using OEM rods. I'd say low 300s then as well.
Old 06-04-2019, 03:08 AM
O.G. triple O.G.
NVturbo's Avatar
Low 300hp, depending on what turbo you're planning to use.
NVturbo is offline
Old 06-05-2019, 01:26 PM
JRCivic1's Avatar
270-300 wheel HP if you keep the redline stock. Less if you plan to rev it up high because of the rods, and no more than 325 to 350 wheel hp because of the stock sleeves if you have done a rod/piston upgrade.
Also, the lower boost pressures the better to meet these target HP numbers... if it takes 25psi to get to 300 wheel hp, it is going to break.
JRCivic1 is offline
Old 06-24-2019, 12:59 PM
I guessing the consincses is 300-350hp. What is I up greaded the rods and run a vtec head. What's the capability of the stock sleeves. Should a block guard help at all. Whats a good one that dosen. Have cooling issues
Old 06-24-2019, 02:58 PM
DaX
DaX's Avatar
Go with CSS instead of a block guard. Standard CSS is rated to 700 hp on stock sleeves. If you're going to do rods, you might as well do forged pistons too. VTEC head is a good idea.
DaX is offline
Old 06-25-2019, 03:22 PM
Txdragon's Avatar
Default Re: what is the power capability for a stock engine B18A/B that is turbocharged?
^^ This.. Go with CSS as your typical "block guard" is garbage. The CSS process is more expensive but, also comes with a guarantee. Worth it..
VTEC is debatable. In my first build I disabled VTEC while tuning. It still pulled really hard. Felt great. When enabling VTEC again, it was noticeable but, meh.. Could live without it. I believe that with a boosted application, VTEC is honestly negligible. On N/A, VTEC is necessary. Just my opinion though.
Txdragon is offline
Old 06-26-2019, 06:30 AM
Moderator
TheShodan's Avatar
I think we've answered everything. The OP can go to the B18A/B Turbo LS setups for more information.
Turbo B18A/B setups page
TheShodan is offline
Nisif
08-30-2012 09:55 AM
got_no_sol
04-14-2008 05:18 PM
Weston
10-15-2006 09:17 AM
thehatchninja
08-29-2005 10:44 AM
boostedinteg03
03-20-2003 12:57 PM
Quick Reply: what is the power capability for a stock engine B18A/B that is turbocharged?
