POST YOUR TURBO GSR HP NUMBERS
#51
Re: (1FastCoupe)
buying a kit this week.... ill have numbers next week Everything in my sig (except ill run open DP till i get a bigger exhaust) and tuning with crome again. Hoping for ~250whp ~175tq @ 7lbs stock block
#52
Re: (strongarm1731)
you guys running stock gsr motors... how many miles do you have? Im picking up a gsr swap from an acura technician that has 170,000 miles on it and i want to swap my turbo kit over, wondering if this is a good idea, still has perfect compression.
Sorry its OT: not trying to thread jack.
#53
Re: POST YOUR TURBO GSR HP NUMBERS (chrisgottigsr)
98b18c1 (stock) in civic. .57 trim t3/to4e
255whp @9psi tuned with hondata stage 2 by Tom Payn on a Mustang Dyno.
#54
Re: (gt42r_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gt42r_civic »</TD></TR><TR><TD CLASS="quote">competely stock gsr - 395.4whp and 262.4tq. Dynojet.
t3/t67 H.O. 12psi.
Tuned by me...AEM EMS
Modified by gt42r_civic at 7:04 AM 2/2/2006</TD></TR></TABLE>
Elaborate
t3/t67 H.O. 12psi.
Elaborate
#55
Re: (donkiman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman »</TD></TR><TR><TD CLASS="quote">
Elaborate</TD></TR></TABLE>
Maybe more timing and racegas? or just better parts
#60
Re: (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">Where did you hear 286 dustin? hehe...kind of an odd-ball #.
I've done over 350 on Pump...stock Engine.</TD></TR></TABLE>
Im not sure where i heard it, I just thought that was around the number on stock internals where it wont be reliable anymore. Is this true? Isnt that around the Hp area where you start messing up stock pistons / rods for reliability?
#62
Re: (vtac sonn)
540 whp / 365 tq - 25 psi t3/t67 .82 stg 5
552 whp / 439 tq - 30 psi borg warner s200
558 whp / 445 tq - 32 psi borg warner s200
results coming soon of borg warner s300 on 30-35 psi and my t3/t67 on 30-35 psi
#64
Re: (vart)
We did 413Whp@ 14psi on pump gas On Our Dyno jet......
JDMC Bulit Block
sleeved GSR
Aries Piston
Crower rods
JDMC valve pring and Ti Retainers
Head Ported By Us
ITR cams
Tuned On Apexi Power FC
Going to Crank the Boost Up But to Lazy to tune IT..HAHAHA
JDMC Bulit Block
sleeved GSR
Aries Piston
Crower rods
Head Ported By Us
ITR cams
#65
94 GSR
Stock block, stock head, stock everything
DRAG Kit
Turbonetics 57 trim .60ar compressor, .63 hot, stage III wheel
35mm TiAL wastegate
Drag piping and intercooler
DSM 450CC injectors
tuned by Cortney with neptune
312 at 12psi (91 pump gas)
There was 140,000 miles on her.
ran a 12.4@114, fly came loose second run. Now doing a full rebuild. Sold the kit and going Big!
DRAG Kit
35mm TiAL wastegate
DSM 450CC injectors
#67
Re: (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic »</TD></TR><TR><TD CLASS="quote">470whp and 290ish tq on a slipping clutch and 15 psi of boost.</TD></TR></TABLE>
whats your setup?
whats your setup?
#71
437whp and 307ft/lb @18psi on 100 octane
stock sleeves 9.8 je pistons and eagle rods.
precision sc44
walbro 255lph
580cc injectors (98% duty cycle on 18psi)
current setup has done 40000 km, daily driven and runs 10s over here in new zealand.
precision sc44
walbro 255lph
#73
Re: (chrisgottigsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisgottigsr »</TD></TR><TR><TD CLASS="quote">
whats your setup?</TD></TR></TABLE>
ERL sleeved gsr 83mm cp 9:1, pauters. Stock gsr ports, ferrea valvetrain, itr intake gsr exhaust. Edelbrock intake S2000 tb (fs ) Full Race prostreet manifold (fs )t3/67 .82 hotside non HO (fs ), FSM 3"dp and exhaust (fs ) gsr trans with quaiffe and gearspeed synchros, Exedy twin disc clutch, AEM ems, direct fire coil on plug, AEM C2DI, Full Race sump, sx inline fuel pump and reg, -10an lines to rail, FSM fuel rail 160# bosch injectors, -6an return, Full Race traction bars, skunk drag coilovers with kyb adjustables, energy suspension poly bushings, Weld magnum 13's with 25's and 15" magnum skinnies with 24's. Probably missing a bunch of ****, but thats pretty much it.
Soon to be mid 700's whp and hopefully high 9's if i ever sell all this stuff to make way for the new setup
