Post Your Sleeved STOCK Bore HP
just want to see how much power u guys are putting out with a stock bore, been thinking about going 83 or staying stock bore and just turn the boost up, i want to gain alot of tq, so im just thinking if going bigger than a 81 will benifit me alot, i know one reason i wanna stay stock bore is cause if something were ever to happen, there is room for error, unless if a rod desides to go for a walk and makes a door for its self, lol then im effed, but if u guys can give some input on it, and set ups your running and HP your making on a stock bore, that would be great, im sure most of you are going to say well if your just gonna stay stock bore, then u might as well just stay on stock sleeves, thats very true and i know its been proven, but i think i would rather just have the extra insurance, thanks for the help and info.
Re: Post Your Sleeved STOCK Bore HP (Dual Cam Racing)
I've made 508whp on 15psi with a 81.5mm stock sleeve motor.
On 15psi I went 131mph or so on a 225 bfg. On like 20-22psi I went 141mph on 225 bfg's. I never dynoed it on higher boost so I'm not sure what it makes I can only assume that it makes around 600whp.
Re: Post Your Sleeved STOCK Bore HP (nonvtecallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor »</TD></TR><TR><TD CLASS="quote">I've made 508whp on 15psi with a 81.5mm stock sleeve motor.
On 15psi I went 131mph or so on a 225 bfg. On like 20-22psi I went 141mph on 225 bfg's. I never dynoed it on higher boost so I'm not sure what it makes I can only assume that it makes around 600whp.</TD></TR></TABLE>
nice, how much TQ u putting down?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing »</TD></TR><TR><TD CLASS="quote">
nice, how much TQ u putting down?</TD></TR></TABLE>I dont remember the TQ but I think it was around 350tq @ 508whp
I dont really like dynos as a number stand point. I really only use as a tuning tool. I could careless about what the dyno numbers are...I like track numbers more.
good lord thats a lot of power on 15psi. Whats the setup exactly?
Re: Post Your Sleeved STOCK Bore HP (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">
good lord thats a lot of power on 15psi. Whats the setup exactly?</TD></TR></TABLE>LS/Vtec 81.5mm 9.1 CR
Eagle rods (small bolts)
B16 head ported by Head Games
Ferrea 1mm over size
Ferrea springs and retainers
CTR cams
JG Victor X intake
BBK 70mm t-body
Full Race top mount single WG
PT 6776 ball bearing turbo
Custom intercooler and piping double back door
Custom made by me 3.5" down pipe and exhaust
Electramotive Tec3 EMS tuned by me.
CTR cams
JG Victor X intake
BBK 70mm t-body
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor »</TD></TR><TR><TD CLASS="quote">LS/Vtec 81.5mm 9.1 CR
CTR cams
JG Victor X intake
BBK 70mm t-body
nice man!
CTR cams
JG Victor X intake
BBK 70mm t-body
nice man!
Yesterday tuned an ERL sleeved 81.50mm B18c5 with 9:1 pistons, stock intake manifold, SFP exhaust manifold, 2.5" downpipe, 2.5" exhaust, SC61E (not sure if T31 or T350 wheel), Ferrea valve train, 38mm wastegate, etc. on a Land and Sea. The SFP exhaust manifold ended up cracking pretty bad and we were not getting full boost until 7000RPM or so. Only made five pulls due to this. I will get the dyno sheet later but I think it made 371whp and 256ft-lbs @ 15lbs
Modified by alpha at 7:47 PM 2/11/2007
Re: Post Your Sleeved STOCK Bore HP (alpha)
last year i made about 330 on stock 81mm bore aebs sleeves lsvtec. was done on about 1 bar but 70-80% leakdown out of #2 exhaust valves, so i can only imagine it should have been a good 30-40+ hp more with 4 good cylinders
Re: (Dual Cam Racing)
Not sleeved but it does answer your stock bore hp question :-)
<FONT SIZE="3">Video Download: Right click & hit save file as to download the video.</FONT>
<FONT SIZE="3">
Alpha's video of the dyno session: Right click & hit save file as.</FONT>
Specs are listed on the sheets.
<FONT SIZE="3">
Re: (mtber)
http://forums.evans-tuning.com...=4392 730whp 81mm gsr
and
http://forums.evans-tuning.com...=4002 630whp 81.5mm b16
and
d16a6 stock sleeves
srp pistons stock bore
eagle rods
t3/t4
tuned on crome by 1320
303hp 250tq
17pounds soon more boost
eagle rods
t3/t4
303hp 250tq
Re: (ngogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngogsr »</TD></TR><TR><TD CLASS="quote">complete stock block= 460whp
tuned by STOOPID</TD></TR></TABLE>
How long have you been running that?
