Post your Half size radiator Setup
Looking to upgrade my radiator Setup, I need to use a pusher fan so I can run a Efficient Turbo intake.
Just post your setup I wanna see what is working for you guys, pusher/puller setup doesn't matter, Post Radiator brand, specifiy 2 row or 3 row radiator, and Which slim fan you use |
Re: Post your Half size radiator Setup
Originally Posted by 2kdrift
(Post 50886734)
Just post your setup I wanna see what is working for you guys, pusher/puller setup doesn't matter, Post Radiator brand, specifiy 2 row or 3 row radiator, and Which slim fan you use Koyo 1570R half/sized dual V-Core SPAL 13" 1800cfm fan puller fan 40Amp fuse No shroud / custom bracket mount Future : Doug Miller custom radiator 3/4 size Twin SPAL 13" fans Aux power connector for secondary fan shroud system for in between sessions at cool down. Fluids: Toyota Pink 50/50 mix - 70% ICE Purple water wetter - 30% Never went above 198F* ... EVER , even after 20 min sessions.. But it would get close. |
http://i1141.photobucket.com/albums/...pszgehmh3a.jpg
Mine. Triple core eBay special civic radiator. eBay shroud and 12" fan. Mishimoto 1.3 bar cap. 80/20 water/coolant mixture with water wetter. Silicone hoses, etc etc. Very rarely ever sees above a 200 degree water or oil temp. |
OP what chassis, engine and setup are you currently running? Thought of a Scirroco or tucked radiator from Rywire or Speedfactory?
1 Attachment(s)
Originally Posted by Bently_Coop
(Post 50887540)
ram horn go auto kit a/c friendly which was stupid should have gotten the non ac kit Havent looked much into those, ill look now. Honestly at this point im looking twards triple row units, even if the third row gets heatsoaked it still allows for more coolant in the system. Right now im between an EBAY CXRACING or a mishimoto not sure the mishimoto is actually anything more then a re branded chinese RAD but from pics ive seen they do look like a bit more quality piece never seen one first hand. Plan on using spal pusher fan rated at 1360 CFM |
China radiator 2 rows , mitsubishi oem fan,
H22 turbo setup oem thermostate 1.1 rad cap, Fan always on not automatic. https://cimg2.ibsrv.net/gimg/honda-t...87acfa73e2.jpg Mitsubishi oem fan https://cimg3.ibsrv.net/gimg/honda-t...2716826557.jpg https://cimg4.ibsrv.net/gimg/honda-t...2a8662ff1e.jpg Old rad fan set up https://cimg5.ibsrv.net/gimg/honda-t...83a1c46b5c.png New rad mitsubishi fan data |
Dont get mishimoto or CX racing. I had the 3 row CX racing and the car would overheat with the quickness. Dont know why but it was definitely the radiator. My Mishimoto 3 row is "Ok". I would go Koyo next time around.
'98 Integra front bumper w/ Full-Race 11" backdoor intercooler
PWR Civic radiator Mishimoto shroud and 12"? fan Spoon 160 F thermostat S300 fan on when ECT > 175 and up to max speed (155mph? Off the top of my head) P72 22T water pump I'm pretty close to 50/50 coolant mix because I forgot to dilute and add water wetter but it doesn't seem picky at all. We'll see once it gets on a road course. The only thing special about my cooling system is that I have to leave the fan on even while on the highway because the intercooler blocks the air dam and the fan never hits stall speed. |
1 Attachment(s)
ebay radiator
13" spal fan triggered via s300 t1 shroud |
1 Attachment(s)
My cousin's Del Sol tuned by D-Rob.
Volkswagon Scirocco Radiator tucked into the radiator support is going to be your best bet. Radiators are affordable, dual pass so they cool more efficiently and saves a but load of space under the hood. If waste gate comes off the front of the manifold you'll need an elbow to angle it down so you don't hit the radiator. This radiator setup accomplishes blocking off that dead space also. Do not use an inline filler though. Get a coolant neck with the rad cap on it. Any fab shop can make you one i think SF sells them or i can fab you one if you go this route. I use a single 12" spal fan no shroud and the car runs very cool. Never sees over 205 making a pass and temps drop right down after the pass. When i street drove this setup it stays 185-190
I'm going to build one like that. I need a good place to get radiator cores.
Neukin half/sized dual V-Core
SPAL 13" 1800cfm fan puller fan 30Amp fuse No shroud / custom bracket mount |
Originally Posted by TheShodan
(Post 50886900)
Currently:
Future : Doug Miller custom radiator 3/4 size Twin SPAL 13" fans Aux power connector for secondary fan shroud system for in between sessions at cool down. |
The Doug Miller will be custom
I use skunk2 dual core rad with stock fan, but i changed the fan settings so that it comes on at 185 rather than 195, and even after very spirited runs for like 30 minutes it never went above 200. Mind you this was in the evening when it was cooler and not burning hot mid day. I also wrapped downpipe and manifold.
2 Attachment(s)
Mishimoto dual
Mardyne 1500cfm fan |
So far with my street car in Texas heat. Oem fan oem Dual core DELSOL radiator. Stays 185-188 highway driving and regulates 182-196 in traffic. Never gets to 200 even with spirited driving and I don't have air flow even diverted to the radiator.
Originally Posted by Turbo-LS
(Post 50926171)
(Post 50886900)
Currently:
Koyo 1570R half/sized dual V-Core SPAL 13" 1800cfm fan puller fan 40Amp fuse No shroud / custom bracket mount Future : Doug Miller custom radiator 3/4 size Twin SPAL 13" fans Aux power connector for secondary fan shroud system for in between sessions at cool down. Fluids: Toyota Pink 50/50 mix - 70% ICE Purple water wetter - 30% Never went above 198F* ... EVER , even after 20 min sessions.. But it would get close. can you point me to the direction in buying the span fan that you use please. I have the koyo rad you recommended. My email address is sdbee84@hotmail.com if you sell it them too. Thanks |
Originally Posted by boosted94gsr
(Post 50926289)
What's your street car setup? I'm familiar with your drag car, but just curious about your street car.
(Post 50926906)
96 coupe with 99 front end si interior. B20vtec pistons rods 11:1 compression. Pte 5976e. Nothing to crazy very basic 400ish hp. It's fun to rape mustangs with. Lol
(Post 50926171)
Originally Posted by tony_2018
(Post 50929548)
I have plans to do the same, sticking with the oem parts. I just found out that del sols vtec, and I think the EM1, had dual core radiators.
