Possible to put R/GSR internals into an LS block?
Re: Possible to put R/GSR internals into an LS block? (kyden)
wouldnt you have to shave a huge amount of material off the deck to get it to work? essentially scrapping the block if it has to be milled again.
Re: Possible to put R/GSR internals into an LS block? (96 GSR-T)
the gsr and the ls block share the same deck hight.
you have to use matching crank/rods, the pistons are "interchangable"
