Plumbing dual waste gates serially
Anyone do something like this?
Dual WG Setup by Jon Kensy, on Flickr
It'd let me link the bottom sides of two wastegates together vs using a T or splitter... but not sure it will be ideal as the ports inside the wastegates are not a full 1/4" in the body of the wastegates.
Anyone do this?
Anyone do this?
Guest
Posts: n/a
Re: Plumbing dual waste gates serially
Undercut + Lack of filler + Stainless + plenty of heat cycles = Weld Cracking
Also, hard to tell from picture but juding from flange connection VS pipe to pipe there isn't a pulser on the machine or the setting wasn't used.
They're actually not undercut
http://www.flickr.com/photos/67031861@N08/8480803286/http://www.flickr.com/photos/67031861@N08/8480803286/ by http://www.flickr.com/people/67031861@N08/, on Flickr
Back purged and TIG'd with 0.035" wire at 40A. Works fine. Don't nit pick not the prettiest lines as 1.75" pipe is still hard for me, but definitely not subject to cracking etc.
Guest
Posts: n/a
Hehe, I knew when you asked specificly about the welds that you had done them. Look at the first picture supplied in first post, the weld is under the plane (given that isn't the definition for undercutting). Everybody starts somewhere, it's all good, but a pulser would greatly help either way. Sorry to stray your topic and make you defend yourself.
I wouldn't run them in series. One wastegate is going to have priority over the other.
Put a 't' fitting between the two so they see an equal pressure.
I run two wastegates on my divided manifold. I run one hose from the holset compressor housing to a mbc to a tee that splits to both wastegates
Yeah, defend myself. The pic is deceiving. This is on my 700 rwhp pump gas bmw. Runs just fine for 10k miles now, no cracked welds yet.. I better hope and pray though!
http://vimeo.com/59877869
Guest
Posts: n/a
Glad to see it worked out for you. Like I said, I have done it before. Some people just don't understand how pneumatics work. To build pressure the void has to be filled and air compressed. Simple concept really.
Who is Mr Robot?
I've never really liked using a pulses, I dunno why lol
But yes I wouldn't run them in series because as others have said, one will have priority
Why are you trying to run them this way? What ems and boost control solenoid.
How will one have priority they clearly open up in tandem
Your pressure source is not the same as what you'll see on the car. You have a large volume and big lines. I've logged the pressure in the bottom of the gates and I can see a delay. There may be other contributing factors that your missing. If the manifold is divided you'll have a delta in backpressure. That plays a role in how fast or slow the gate opens and closes.
Your test is cool, but it's not what is happening on the car. Sorry.
EDIT: Just realized that you're not using a divided manifold there. That pretty much negates my arguement. lol
5thgencivic
Welding / Fabrication
03-18-2005 12:36 PM
