Please recommend a turbo manifold for an itr motor.....
Actually, could you recommend a couple?
Requirements:
-t4/t3 drag/ turbonetics turbo
-b18c5 longblock
-will retain ac and ps
I would like to get recommendations on a manifold that is equal length and will adhere to the above.
2nd recommendation is for a cheapie that isn't an equal length one...
Please also note whether there is an optional 3" downpipe (preferable), and whether I would need to notch the block, etc.....
-tia
Requirements:
-b18c5 longblock
-tia
Re: Please recommend a turbo manifold for an itr motor..... (Black R)
Full-Race AC Manifold.
Just got done installing one. A little more work, but well well worth it since it retains AC
LoveFab shorty (check in with Cody to see if hes designed an AC friendly SST)
InlinePro
SFP
drag
and if you have the cash.... go with the above stated... Full Race AC friendly
InlinePro
SFP
drag
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">Actually, could you recommend a couple?
Requirements:
-b18c5 longblock
-tia</TD></TR></TABLE>
If you are willing to pay for it, no doubt full-race AC manifold. I'm not sure if it's PS compatible. However, you will need to use a Civic rad. Definately has 3" dp. If you have the dough, PM Geoff, I'm sure nobody knows his manifold better than him.
Lovefab Sidewinder cast looks promising. Equal length, AC and PS compat and priced hundreds less than the full race. Not out yet so there aren't any reviews.
Only log manifold I'd get is the inlinepro. Crackproof and wg port is more central than revhard which it copies. You can either make a 3" dp for this or get a revhard dp and flare to 3" once it clears the PS, which is what I'm doing.
Requirements:
-b18c5 longblock
Re: Please recommend a turbo manifold for an itr motor..... (Rain_man)
the sidewinder is out BodyKits nw had one as well as a few other people here. oh yea Skooter has one too .
made really ncie output.
LoveFab Cast sidewinder!
- Equal length runners allow for the fastest spool up possible, with the highest HP out of any cast manifold.
- The unique casting design allows it to last as long as your car!
- Utilizes a V band connection for the "arm" which allows the turbo to
pivot for any specific application fitment.
- ANY wastegate can be used (manifold will be drilled and tapped) but it is designed for a Vband 44mm Tial wastegate.
- Tapped for a T3 or a T4 turbine housing.
- Fully A/C compatible with a 3" Down Pipe!
599.99 + shipping!
Some rough pics of the first manifold (the flanges are finished now)...
PM me for inquires!
Thanks
Bryson
599.99 + shipping!
PM me for inquires!
Thanks
Bryson
