Pistons rings???? PLease help!
Well i bought a set of used pistons for my D-series... and well I want to buy new rings for them.. theya re standard bore.... what kind of rings should I use... Sould i buy anew set from SRP or are tehre onther brands taht would work better???? thasnk !
I would not go with the SRP ring personally... Some like the OEM Honda or the Total seal rings if they are seated correctly ( beaten correctly as the engine is fired...)
Re: Pistons rings???? PLease help! (cueballsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cueballsi »</TD></TR><TR><TD CLASS="quote">Well i bought a set of used pistons for my D-series... and well I want to buy new rings for them.. theya re standard bore.... what kind of rings should I use... Sould i buy anew set from SRP or are tehre onther brands taht would work better???? thasnk ! </TD></TR></TABLE>
just get on summit and get a new set of je/srp rings; they're like $77 iirc i lucked out; i bought a set of used srp slugs and the used rings on them were still in spec as far as end gap for my motor https://honda-tech.com/forums/images...es/emsmile.gif |
