Performance Gains / Benefits of these injectors..
Old 06-08-2010, 06:20 PM
wtsapexipowerfc's Avatar
Default Performance Gains / Benefits of these injectors..
DSM blue tops
vs
550cc high impedance RC injectors
What benefits will the 550cc high impedance RC injectors provide over a set of DSM blue tops
my power goals will be met adequately with DSM blue tops
250whp 13psi ...
In the end is it really worth spending $310 on newer style high impedance injectors? when I have perfectly working DSM blue tops?
Old 06-08-2010, 06:29 PM
Turbo-LS's Avatar
Default Re: Performance Gains / Benefits of these injectors..
no just run the dsm's there small enough that control for idol isnt an issue
Old 06-08-2010, 07:02 PM
Moderator
TheShodan's Avatar
well, the 550cc will work a bit better at lower fuel pressure of 43psi, by having a lower duty cycle. at the same time, it could pool a bit more fuel. If you ever plan to make more than your 250 whp, you'll be very limited with the "blue tops".
Both will work, but remember the need for a resistor pack with the 450cc.
eg2jr
10-21-2008 11:16 AM
b20hammer
03-22-2004 01:10 PM
88crxvtec
08-31-2003 11:55 AM
Quick Reply: Performance Gains / Benefits of these injectors..
