PeakBoost Kit on a Laskey built LS/VTEC Motor??
What kind of numbers would I be at if I threw a PeakBoost B-Series Turbo Kit with the GT35R Upgrade on my 2000 Si. I'm looking to get 350whp on a Street Tune and 450+ on a Race Tune... Here's the motor:
B16 Head
PortFlow Port & Polish
SuperTech Stainless Steel Nitride Coated Valves
Dual Valve Springs
Titanium Retainers
Competition 3 Angle Valve Job
B18B1 Block
Benson Sleeved
Benson Balanced and Micropolished Crankshaft
CP 9:1 Pistons and Rings
Pauter Rods
ACL Bearings
OEM ITR Oil Pump
Lower Gasket Set
Blueprinted
Let me know what ya think
B16 Head
Dual Valve Springs
Titanium Retainers
B18B1 Block
Benson Sleeved
Pauter Rods
ACL Bearings
OEM ITR Oil Pump
Lower Gasket Set
Blueprinted
Re: PeakBoost Kit on a Laskey built LS/VTEC Motor?? (zeimbo)
you should have no problem making alot more then 450whp on race gas with a proper tune
Re: PeakBoost Kit on a Laskey built LS/VTEC Motor?? (Si_Guy2000)
That should be very easy for you to make. You will prolly end up with 400 on pump. That turbo is good for 600+whp.
Re: (Si_Guy2000)
450 may be a little too much for that turbo. Not saying it wont do it, but it may take more boost to get you there instead of running lower boost on the 35R.
