Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   P2W CLEARANCE AND RING GAP HELP (https://honda-tech.com/forums/forced-induction-16/p2w-clearance-ring-gap-help-3014881/)
Dc4LsTeG Jan 8, 2012 02:53 PM
I'm in the process of rebuilding my b18c5 and I was wondering what p2w clearance and what should I gap my rings to?I searched but could only find info on forged set ups.I'm using 81.5 Nippon pistons w/ Nippon rings, flame on its just until I can get some forged internals..
Set up:
B18c5
81.5 Nippon pistons
10:1 comp.
.60/63 t3/t4
10-15 psi
Pump gas
This will be a dd. So if you can please help me and let me know what I should gap my rings to and what my p2w clearance should be before I take the block to the machine shop.
Let me know if any more info is needed and TIA:thumbup:
Dc4LsTeG Jan 8, 2012 03:36 PM
Re: P2W CLEARANCE AND RING GAP HELP
Or should I stick with OEM specs?not sure if I should keep them a little looser since its boosted?
00Red_SiR Jan 8, 2012 04:22 PM
I would go with the low end (loose) of OEM specs.
Dc4LsTeG Jan 8, 2012 04:37 PM
That's what I was figuring but I wanted to get other peoples input..thanks for your response.
Any other opinions?
rich7777 Jan 8, 2012 11:54 PM
I agree with both the guys what posted up.
Dc4LsTeG Jan 9, 2012 08:32 AM
Ok thanks..anyone else?
