P07 ecu w/ hondata s2000 work on gsr eg?
whats up guys? i was gonna buy a P07 ecu w/ hondata s200-- will that work with a gsr swapped in an eg?? im not a noob, i have just always used aem ems, so dont give me some dumbass answers! i was told that it really doesnt matter what ecu u use with the s200! let me know and thanks!
Re: P07 ecu w/ hondata s2000 work on gsr eg? (bunnyrabbit)
It's not listed on hondata's site, but you may be able to convert the ecu to work. I've personally never used a p07.
Go Tigers!
I believe that i recall reading that the p07 is some weird *** ecu that is completely different from the p28. It's got all this extra **** in it to enable it to run ultra lean for the mpg. Nobody messes with thesee boards. But the p07 from cali is the same board as a p28, just with the p07 maps on it.
Re: P07 ecu w/ hondata s2000 work on gsr eg? (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">I believe that i recall reading that the p07 is some weird *** ecu that is completely different from the p28. It's got all this extra **** in it to enable it to run ultra lean for the mpg. Nobody messes with thesee boards. But the p07 from cali is the same board as a p28, just with the p07 maps on it.</TD></TR></TABLE>
Yes that is correct. It actually incorporates two processors. I believe one from a dx and one from a cx, which doesn't mean anything. Just that one is used for the wideband O2 that it uses, and the other does the actual fuel/timing junk.
i dont need any ecus- i have some, i was just told that the p07 w/ s200 would work on an gsr eg- that with hondata u could control the ecu, so i didnt really matter what ecu u used- i didnt think that sounded right so i wanted to check for sure!
Re: (bunnyrabbit)
http://www.hondata.com/ecus.html
hondata wont work with a p07....u need an ecu that can be socketed and has the right cpu to run the hondata code...
Re: (2k.civic.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si »</TD></TR><TR><TD CLASS="quote">http://www.hondata.com/ecus.html
hondata wont work with a p07....u need an ecu that can be socketed and has the right cpu to run the hondata code...</TD></TR></TABLE>
I am pretty sure only the cali version can be used. Either way I would do a P28 or P72 for your car. Are you keeping IABS?
Re: (RMS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMS »</TD></TR><TR><TD CLASS="quote">the cali version of the P07 is absolutely compatable with s200 and s300. personal experience </TD></TR></TABLE>
cali version...do you know which revision that is...
Re: (2k.civic.si)
cali version...do you know which revision that is...</TD></TR></TABLE>
Yea the version made for cars in california. If you open it up and it looks like p28 inside, that is the cali version.
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">
Yea the version made for cars in california. If you open it up and it looks like p28 inside, that is the cali version. </TD></TR></TABLE>
ya i get that much...whats the pcb revision smart guy
