P.I.T. BCU+ reviews? any1 ever used this boost controller?
was thinking bout getting this EBC, wus 1dering if any1 had good or bad experience w/ dis EBC... lmk guyz thanx...
BCU+ link
http://cgi.ebay.com/ebaymotors/Elect...Q5fAccessories
Specs:
Compact Design
The BCU+ comes in a 4.17" x 4.65" x 1.1" compact design and uses on the the smallest solenoids around for an easier installation both inside the car and under the bonnet.
Information Display
The BCU+ has an LCD screen so that all the functions and settings can be viewed.
Boost Setup
Two different boost levels can be easily setup by turning the Hi and Lo *****
Safety
The BCU+ has multiple safety features. Over boost - The LCD background display will turn red and an audible alarm will both warn the driver if over boost occurs. Limiter - The BCU+ has limiter which will limit the amount of overboost by modifying the opening of the solenoid based on the preset limited % and preset boost.
Turbo Timer
The BCU+ has a manual and automatic turbo timer. The manual timer allows the engine to run for a specified time adter the key has been removed from the ignition; and the automatic timer allows the engine to run for a certain amount of using voltage variation once the key has been removed from the ignition.
Channel Outputs
The BCU+ boost controller can be programmed to activate and deactivate electrical components when certain specified criteria are met.
Complete Kit
Vacum tube, cables and solenoid valve are all included
BCU+ link
Specs:
Compact Design
Information Display
Boost Setup
Safety
Turbo Timer
Channel Outputs
Complete Kit
Re: P.I.T. BCU+ reviews? any1 ever used this boost controller?
First of all, they're obviously based in the UK. Shipping will really hurt. Second, it seems to be an electric version of a MBC (mean YOU adjust boost, not gear/speed-based), along with a turbo timer and a programable output. For the price you'll find if for from US shops, you'll definately be better off with Apex'i or Greddy.
1A4
02-02-2007 12:01 PM
