EAGLE RODS WONT FIT FOR TURBO SETUP...NEED HELP!!!
Old 07-18-2004, 05:51 PM
slammedcoupe's Avatar
Default EAGLE RODS WONT FIT FOR TURBO SETUP...NEED HELP!!!
Just what it says, I bought a set of Eagle H-beam rods and they just wont fit. I pulled the motor and took out the crank, switched the bearings over, put the SRP pistons on and then put the crank back in. Now i put the rods down with pistons attached of course and once i put the rods together and try to spin the crank, it only goes halfway because the rods touch the wall, the very bottom of it.
What shold i do???
Old 07-18-2004, 05:57 PM
TurboJesse
Guest
Posts: n/a
Default Re: EAGLE RODS WONT FIT FOR TURBO SETUP...NEED HELP!!! (slammedcoupe)
SEARCH
This has been covered a million and 1 times
Old 07-18-2004, 05:59 PM
B18C1CYA's Avatar
if this is a d series you must notch the bottom of the cylenders, do a search it a very comon thing with after market rods in a d series
sxysweed
05-29-2012 06:43 PM
bigsnorlax
03-11-2011 01:22 PM
4door hobo
10-19-2006 03:03 PM
slammedcoupe
07-18-2004 09:49 PM
slammedcoupe
07-18-2004 06:53 PM
Quick Reply: EAGLE RODS WONT FIT FOR TURBO SETUP...NEED HELP!!!
