Outline for Strader Performance/Jotech EFI Tuning Seminar
Here is an outline for the efi tuning seminar being held at Jotech and taught by Ben Strader. This seminar is being covered by Turbo Magazine and some of the big names attending will be Endyn's own Larry Widmar, Kenny Tran, Bob Norwood (I think), Arturbo and I am coming along as your food and drink server. Two spots have opened up in the seminar Check out this outline
Ben Strader’s EFI Tuning Seminar
OUTLINE
I. What is Tuning?
A) Calibrating an engine via Laptop
B) Creating a program that allows the engine to function in a certain manner consistent with the desired application
C) The process of testing and rearranging the files in a table that commands engine functions of a given nature
II. Why do we tune?
A) Maximum performance
1. power, torque
B) Drive-ability
C) Fuel Economy
D) Throttle response
E) Ambient conditions change
1. altitude
2. temperature
3. fuel quality
III. What things in a calibration can we tune?
A) Main fuel tables
B) Main Ignition Tables
C) Boost Tables
D) Idle Settings
E) Rev Limiters
IV. What kinds of Modifier Tables do we tune?
A) Cold Start Extra Fuel
B) Cold Start Extra Fuel Time limits
C) Warm-Up Ignition Tables
D) Warm Up extra Idle speeds
E) Acceleration Enrichment
F) Deceleration Fuel Cut
G) Altitude and Temp Correction
H) Battery Voltage Compensation
V. What Kind of A/F Ratio does the Engine want?
A) Idle
B) Part Throttle Light load
C) Part Throttle Heavy load
D) Full Throttle N/A
E) Full Throttle under Boost
F) Transient Throttle Accelerating
G) Transient Throttle Decelerating
H) Injection Timing Relative to crank position
VI. How Do I know how much Ignition Timing the Engine Wants?
A) Idle
B) Part Throttle light load
C) Part Throttle Heavy Load
VII. How to read the Engine’s tell-tale signs of performance
A) Spark Plug color on porcelain
B) Spark Plug color on ground strap
C) Piston color on top
D) Exhaust pipe color
E) How does it sound
F) How does it feel
VIII. Dyno Tuning or Road Tuning; Which is better?
A) Dyno provides accurate readings
B) Dyno is a safe, controlled environment
C) Road or track tuning can be different than dyno
D) Dyno won’t provide every situation like atmospheric conditions
E) USE BOTH FOR THE BEST TUNE
IX. Tools of the Trade
A) Dyno
B) A/F Meter
C) Infrared Temp Gun
D) Spark Plug Light
E) Standard Test Light
F) Self Powered Test Light
G) DVOM
H) Oscilloscope for experts
X. Auxiliary Functions
A) VTEC Solenoid
B) IAC Valves
C) Nitrous Solenoids
D) Boost Solenoids
E) 2 Step Rev Limiter
F) Anti-Lag Function
G) Traction Control
XI. Fundamentals of Wiring
A) What size wire to use?
B) Solder or crimp ?
C) Use a relay or not?
D) Covering your wires
E) Making solid connections with solder
F) Making solid connections with crimpers
G) Using the correct connectors
XII. Tuning process from Start to Finish
A) What Octane will the engine run normally?
B) Is this the same octane that will be calibrated with?
C) What is the compression ratio?
D) Turbo, Supercharger, Nitrous, or N/A
E) Setting Fuel Pressure
F) Getting Started and Running
G) Set Mechanical Base Timing
H) Tune Engine to Idle properly after warm-up
I) Tune No-Load RPM sites
J) Tune No-Load Accel Enrich sites
K) Begin Part load tuning
L) Begin Moderate to heavy load tuning
M) Full Load tuning
N) Review data logs and power graphs
O) Make necessary changes
P) Street or Track testing and tuning
Price is $300. See you in the big D
Earl
OUTLINE
I. What is Tuning?
II. Why do we tune?
1. power, torque
B) Drive-ability
C) Fuel Economy
1. altitude
2. temperature
3. fuel quality
A) Main fuel tables
C) Boost Tables
D) Idle Settings
E) Rev Limiters
A) Idle
A) Idle
F) How does it feel
A) Dyno
B) A/F Meter
D) Spark Plug Light
G) DVOM
A) VTEC Solenoid
B) IAC Valves
D) Boost Solenoids
G) Traction Control
M) Full Load tuning
Earl
Re: Outline for Strader Performance/Jotech EFI Tuning Seminar (ben@importparts.com)
I cant wait for this to go down lots of people to meet and lots of info to learn. And maybe Mike and Ben can finally finsh the debate on which is better cdi or dis hehe.-pete
Re: Outline for Strader Performance/Jotech EFI Tuning Seminar (bambooluv)
do you guys plan on hosting the same seminar in california anytime soon? also, does this seminar include hands on training?
Re: Outline for Strader Performance/Jotech EFI Tuning Seminar (Suprdave)
Due to the legnth of the seminar and the difficulties involved in sound and video recording and then editing the seminar in order to have a professional look, we have decided not to record and sell the seminar.
However, IF this seminar goes as well as it looks like things are shaping up, we will seriously investigate having several seminars each year all over the USA and possibly even entertain some extra-continental activities like Japn, Australia and Europe.
This idea, of course is fairly aggressive and could be a big program, so we'll just go one seminar at a time.
Also, based on the response of this tuning seminar, I am also thinking about the possibility of arranging some sort of retainer with a few of the larger manufacturers of EFI systems which will allow me to travel around the country and train their dealers and end-users, as well as provide track-side technical support for their products.
Just some thoughts for the future.
-Ben
-Ben
Re: Outline for Strader Performance/Jotech EFI Tuning Seminar (1.8T_EG)
Florida, NY/NJ, Chicago are places that YOU can be the organizer. We will peobably have one in Cali. Basically, you need 10 paying students and we can bring the show to you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambooluv »</TD></TR><TR><TD CLASS="quote">I cant wait for this to go down lots of people to meet and lots of info to learn. And maybe Mike and Ben can finally finsh the debate on which is better cdi or dis hehe.-pete</TD></TR></TABLE>
With out a doubt, the dis-4 HO model is stronger. Where I get my facts from, thats my secret...haha.
Re: Outline for Strader Performance/Jotech EFI Tuning Seminar (ninesecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx »</TD></TR><TR><TD CLASS="quote">
With out a doubt, the dis-4 HO model is stronger. Where I get my facts from, thats my secret...haha.</TD></TR></TABLE>
silly child
That's right.........follow the pack like the good little sheep do!
silly child
Re: Outline for Strader Performance/Jotech EFI Tuning Seminar (EFIGUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFIGUY »</TD></TR><TR><TD CLASS="quote">
silly child
That's right.........follow the pack like the good little sheep do! </TD></TR></TABLE>
Show me the cliff and ill jump
silly child
Re: Outline for Strader Performance/Jotech EFI Tuning Seminar (slowsi00)
its at jotech motorsports located in garland TX right off the main highway 635.
