OT: does an LS long block from oil pan to valve cover including IM fits in the trunk of an Integra ?
I am planning on buying an LS long block about 4 hrs away in houston, can I fit the Long block inside the trunk of a integra ?
thanks..
stan
thanks..
stan
Re: OT: does an LS long block from oil pan to valve cover including IM fits in the trunk of an Integ
mine fit on a 2g, it will be a mess though, hope oil/coolant was drained
Will you make something up for me please?
Mine is sitting on my garage floor now. It's approximately 23 inches high starting at the oil pan to the top of the valve cover. It's approx 27 inches wide from the end of the distributer to the driver's side motor mount.
You might be able to get it farther in if you fold the seats down.
The hatch won't close if it's in the "trunk part" It's pretty high. Maybe if you get rid of the spare tire. Just be careful, I dunno how the heck you're gonna get it in there, it's heavy as hell.
Good luck.
Good luck.
I put my entire B18C1 long block including Skunk2 IM into the back of my girl's EK. Had to remove the spare....and cushin the bottom so it didn't move too much. I've also seen people remove their front passenger seat and transport their longblocks that way. Just gotta tie it down. In any case it'll work....took 3 people to lift the ****** into the trunk and a cherry picker to remove it.
-Trung
[Modified by Projekt20, 6:22 AM 3/20/2002]
-Trung
yeah, oil and coolant will be drained out
damn...thanks for the measurement, I was planning to take out the spare tire and locate is somewhere else....
so you think with no spare tire, it'll fit ?, supposedly if I took out the trunk lid and folde the rear seat down ?
stan
PS: if not, I might need to borrow your truck Say.. hehehe
stan
It will fit, but its heavy as hell , since your pikcing up the long block. The short block itself is probably like 150-180 lbs. Two people can lift it into the car pretty easily.
If possible, remove the head and put the head on the passenger seat and the block in the back.
New User
the best way to do it is to put the motor in the passenger side, with the seat removed.
Yes, it fits in the back of the hatch. I did it with my spare block.
art
art
iv put an entire gsr in the back of an eg before... block/head/tranny and shift linkage all together!
GO RENT A TRUCK MAN!!!!!!!!!!!!
In my area Budget is renting Ford Rangers for $19.95 a day, unlimited mileage. I am not sure if that price is the same in TX but it is a special Budget is running nationwide. For the $20-50 it costs to rent a pickup you will save yourself a ton of trouble. Plus, I don't know how I would feel about putting a dirty *** engine my my car. It cannot be safe, it will almost undoubtedly ruin something and you will truely look like an idiot to whoever passes you on the 4 hr trip home
Good luck though, I am looking for a LS longblock too. I plan on building whatever i buy and saving my stocker with its 18K miles just in case I blow something.
art
the whole long block ?
art
New User
if thats the only way you can do it... its heavy as fock! i could barely carry a d16 motor.
hafaadaiteg
06-06-2007 01:15 PM
Dr Pooface
09-26-2006 08:36 AM
