OT: Can you run these at the track?
Will they let you run sand rails at the track?
Is there any special rules to running a "car" down there...like need for a windshield, doors, etc? The sand rail is basically a big roll cage
The cool thing is...it probably weighs around 1000 LBS with the engine...around 200 HP (flywheel)...should be running low low 12s...if not high 11s
Re: OT: Can you run these at the track? (FAST94GSR)
Hmm...think so? What safety equipment would it need?
It has a roll cage (hell..it is a roll cage) and 4 point seat belts...what else is needed?
Re: OT: Can you run these at the track? (HX_Guy)
I often go to Maple Grove and on test and tune days they sometimes have a few snowmobiles and 4 wheelers running. I would get in touch with the track you plan to run at and ask them.
Re: OT: Can you run these at the track? (boosted3g)
Ouch...well I just called the local track.
It seems you can run them...but you have to have quite a few safety things...alot more then normal.
You have to have a 5 point harness, window nets, arm restraints and DOT tires.
Damn...guess we're not going to be running it
