Opinions requested: B16a gt3582 and pro 1 cams. Mid range & top-end possible?
#26
Moderator
Re: Opinions requested: B16a gt3582 and pro 1 cams. Mid range & top-end possible?
If you want more power lower longer stroke is your answer or using the quick spool feature on s300 also makes a massive difference in the mid range, along with more boost tapering off like Baylor said. The quick spool (if your not using it yet) will make the single largest cheapest difference on your setup. It keeps the pwm at 100% to keep the wg fully closed till the targeted boost for quick spool is reached.
#27
I was about to say you will not see more than 15-20hp from victor X to S2 but i didnt want to discourage him.
GT3582 TO GTX "3576"
Shodan might chime in on the turbo conversion.Or get real cams.
Other than that get water/meth injection and use aggresive boost by rpm.
#28
#30
If you want midrange out of the intake you need to maximize runner length.
#31
I think so too...Evans tuning told me the best solution for B16 is pro 1 with ultra street...
#32
Agreed that either GSC T1 or Kelford 176-C would be a better option than Pro1's for midrange.
#33
Im very sure something is very wrong here
Never ask the big names what to buy on ANYTHING.
Id still do either turbo conversion with smaller billet wheel or water meth injection for aggesive boost by rpm with lower timing and leaner afr before cams.
#38
after 7500 the car is very strong already.
#39
Interesting, for road racing you would want more low end torque and a turbo capable of spooling pretty quick rather than midrange of 7000-8000 and top end power. The setup you are putting together is more of a drag racing setup and not road racing. Now 7000-8000 RPMS really isn't midrange but closer to top end power especially if you are only revving up to 9500. I mean if you were only really using this for drag racing a Pro1 and Victor X is a pretty good combo and would give you a really good peak from 7000-10000 RPMS.
#40
#41
Moderator
#43
#44
Moderator
Everything. And I mean almost everything must be changed.
-Turbocharger - No larger than 51lbs/min (GTX2867R, Banshee, Hunter, or GTX3067R at the largest). A GT35R is a complete waste of time for what you're trying to achieve here. No camshaft or electronic setting will save this system. Sorry.
-Intake manifold - Skunk2 Pro 1, Edlebrock Performer X, or even a good Type R. (For God's Sake NO Victor X, or Ultra Street)
-Camshaft - Kelford 176-T, GSC T1, or even a nice TypeR or Tuner 1
-If possible B18C1 or something with larger stroke if you can.
I hope you don't have some huge runner exhaust manifold like a Kooks "Ramhorn" or Top-Mount manifold, because that has to go to.
Your entire current setup is geared towards drag racing, and drag racing only. There's no dual purpose for what you have here with this B16.
The Boersma Time Attack EM1 civic is a Perfect example of a Road Race setup
The perfect torque curve. Flat as a table, 250ft-lbs from 4000rpms to 9000rpms. That can't be beat . A B16 would not make as much overall torque, but with lighter tare weight of the car, it would still be close.
B18C1 9.6-9.8:1 CR
B18C5 Head / ITR Cams
Skunk2 Pro Intake Manifold
Short runner tubular log exhaust manifold
CSF Full sized Radiator
Garrett GTX2867R Turbo @ 20 PSI
Custom Backdoor Garrett FMIC 3" DP / 3" Exhaust
HKS SSQV Chipped OBD-I
420.6 WHP & 256.8 WTQ ---> (With a Banshee, TR3030R, or GTX3071R, you could get 490-500whp with 272WTQ in a B18C1, about 240WTQ in a B16, but for a shorter period of time)
Boersma B18C1 Civic Lap Attack v.1
B18C1 9.6-9.8:1 CR
#45
B18C1 9.6-9.8:1 CR
B18C1 9.6-9.8:1 CR
with 3582 I can run 100-200 kmh close to 5 to 5,5 sec with 2867 never.i have a very fast road race car and I try to make it faster...
#46
I think there is some "lost in translation" happening here . I think the OP means "fast street car" or roll racing on the street rather than "Road Racing". In the USA, "road racing" means circuit track (Laguna Seca, Buttonwillow, Circuit of Americas etc.) while "street racing" or "roll racing" means a high horsepower street car racing others on the street. @TheShodan was suggesting a setup based on an understanding of "road racing" which implies a road course (outside of the USA we refer to road course as "track", whilst in the USA "track" usually refers to drag strip).
SO....if your purpose of this car is street racing and you looking for more mid-range power so the car accelerates faster earlier in the powerband then the simplest solutions are A) change the turbo to GTX3576 Gen 2 specs or B) Build a B18B or B18C bottom end to gain extra capacity and therefore more mid-range torque.
A B16 and GT3582 combination is always going to be gutless down low. Could cams with larger primary lobes like the Kelford's and GSC's help - yes but they aren't going to cure the fact that your powerband only starts at 6000rpm+ with your engine size and turbo combination - due to you not having boost and therefore corresponding airflow before that rpm point.
#47
Moderator
Those are good points extremeracer. Excellent referencing of terminology. We must come to a common definition of the OP's purpose here, and the correct understanding of the definitions is key...
Thanks for pointing that out. OP, the ball is in your court; not just numbers regarding acceleration, or dyno charts or any of this, but actual purpose of the car. Use, events (if any), etc.
#48
Yeah that's why I was asking what the purpose of the car was and he said road racing and some drag racing but he was looking at getting better power starting at 7k which seemed weird for a road race car. However if he was looking for power from 7 to 10k Victor X and Pro 1's would give him that if he meant he is looking for a roll race/drag race car. For roll racing and drag racing you don't need to worry about power under 7k because you technically should never fall below 7k between shifts when roll racing/drag racing.
I did 0 to 212km in 5.9 seconds with the Victor X, Pro 1's and 74mm throttle body and made great power from 6,500 to 10,500RPM's
#49
thank you all for your time!
#50
Moderator
Man, that was so confusing. It's amazing what a little terminology cleanup can do for helping up. Wow.
