open carter and valvecover ventilation bad?
no vacuumsource to carter-ventilation and valvecover-ventilation bad?
can it harm the engine? that is if i change oil enough? if so why?
thanks!
Modified by dnbruut at 8:07 PM 9/15/2005
thanks!
Re: open carter and valvecover ventilation bad? (dnbruut)
maybe its a stupid quistion but there aint a answer in the books so please help me out!
kinda confused by the question.
Are you asking can you just leave the breather on your valvecover open with nothiig on it? No you cannot unless you like oil all over everything.
What is an open carter????
Rereading your post before you hit submit is a great idea to make sure you spelled **** right and you make sense in your posting.
Re: open carter and valvecover ventilation bad? (mike1114)
i'm sorry for pissing you of or confusing you.
my quistion is:
can it harm the engine if i don't put a vacuum source to the valvecover-ventilation and to the carter-ventilation?
i know if pressure and gasses can't escape it will harm the engine and oil but does itneed a vacuum or would it be OK to leave them open(with a small flter or catch-can)
thanks!
my quistion is:
thanks!
mine are open to the atmospere until I can buy or make a catch can and the valve cover breather and crankase evacuation ports dont blow out a ton of oil, they do blow out some but its only like two or three drops a month nothing that you should worry about. Ive been running my car like this for about 3 months and no problems from it
Re: open carter and valvecover ventilation bad? (h kid)
ok thanks and you dont have any oil contamination? black sludge?
annyone else got any thoughts on this?
compprat
21
06-13-2006 06:30 PM
