once and for all...how accurate are the autometer a/f gauges?
i have asked this before and never received a straightforward answer and mainly speculation on the accuracy of these gauges. so, should i worry if i'm boosting and it shows that i'm running lean or is just a light show?
Re: once and for all...how accurate are the autometer a/f gauges? (boostedeg6)
i have an autometer a/f gauge... the downside i see to it is that it does not give you a detailed reading of your a/f mixture which is necessary for tuning...
but it does get its job done telling you if you're running rich at wot or what not
Re: once and for all...how accurate are the autometer a/f gauges? (SagaGSR)
it is not good for very much except a ballpark reading. not meant for tuning or for anyhigh performance use. i have a standard a/f gauge in my car which is nice... but when you tune, you want to use a wideband lambda meter. these o2 sensors operate on a 5volt signal which gives a much more detailed range of o2 accuracy than the standard 1 volt signal sent by the stock sensor..
so in a nutshell
standard... good for day to day in car use to see whats happening NOT for tuning
wideband... a must for use on a dyno while tuning car
mmmmkay?
so in a nutshell
mmmmkay?
New User
Re: once and for all...how accurate are the autometer a/f gauges? (TurboR616)
I agree with TurboR616. The Autometer is what I currently have in my car. It basically will let you know if you are running rich or lean under WOT conditions. It will not give you an actual A/F Ratio.
If you really want to tune using an A/F gauge, I would recommend the setup by Greddy. This gauge uses its own O2 sensor, and will display the actual A/F ratio. A must for proper tuning. It also has a memory feature. The thing will set you back over $200 though.
If you just want a ballpark figure get the Autometer.
Personally, I plan on changing mine to the Greddy real soon.
Re: once and for all...how accurate are the autometer a/f gauges? (Big James)
the greddy is NOT a wideband o2 gauge.... the gauge itself is adjustable for use with a wideband sensor... howeever it doesnt come with one.. just a regular ol 1 volt.
New User
Re: once and for all...how accurate are the autometer a/f gauges? (pest)
i use one on my car.. and when i see it run lean and stay lean.. im assuming that it's not good. it runs rich and bounces all the time but when it hits lean, i let up! dont know how acdcurate it is.. but it wasnt wrong before... when i had fuel pump problems.. it ran lean and the air/fuel showed me the corresponding result..
Re: once and for all...how accurate are the autometer a/f gauges? (GSRwBOOST)
Actually, the greddy is not compatible with a wide band sensor.
They recommend you calibrate it against one however.
But since it doesnt have temp correction its not as good as a true wideband
Re: once and for all...how accurate are the autometer a/f gauges? (sgT)
Only use the a/f gauge at WOT, pointless otherwise. Best is to use the a/f gauge in conjunction with an EGT.
Re: once and for all...how accurate are the autometer a/f gauges? (98hx99b18c)
Re: once and for all...how accurate are the autometer a/f gauges? (SW20 MR2)
Seems reasonably priced.
I wonder how it compares with the other brands(eg motec, autronic, etc)
Re: once and for all...how accurate are the autometer a/f gauges? (SiRkid)
It actually came in handy when I was adjusting my fuel map with closed loop and open loop. If it was too rich on closed loop either on idle or cruising it would tell me so I changed it whatever needed to be changed. It helped a lot. So for now Im gonna go with what I have until i get my 3" downpipe and go to dyno and tune it with a wideband o2.
Re: once and for all...how accurate are the autometer a/f gauges? (9psiLsT)
thanks for all the responses. has anyone tried the gadgetseller gauges at the link above? they are supposed to modify your current gauges for WOT readings. i wonder how accurate they make these gauges.
hondaguyexsi
10-08-2005 06:58 PM
