okay guys, i need your advise....oil cooler??
Old 05-14-2003, 09:14 AM
turbochic's Avatar
Default okay guys, i need your advise....oil cooler??
I am just about done with my install on my d16y8. I will be driving my car on the street for about a year, then after that it'll be used only for racing. I have the stuff in my sig, now here are my questions:
-should I get an oil cooler?
-if I need one, should I get an already put together kit? or make my own?
-if i should buy a kit, what should i look for? (not too knowledgeable on what to look for, size, etc etc)
-if i can put one together on my own, what parts do i need?
-also on my oil temp gauge what temps should i worry about WITHOUT an oil cooler?
I am on a pretty tight budget as Im sure most of us are, so ANY help would be so much appreciated, since I will be making the purchase if needed this week.
THANK YOU SO MUCH!!
Old 05-14-2003, 11:19 AM
turbochic's Avatar
Default Re: okay guys, i need your advise....oil cooler?? (fmaxturbochic)
c'mon guys......anyone??? I know someone has some idea.
Old 05-14-2003, 11:29 AM
sporkcrx's Avatar
Ditto, I plan to road race every once in a while w/ the turbo and I wonder if I need to get an oil cooler since there will be a **** load more heat.
Old 05-14-2003, 11:50 AM
forcefed's Avatar
Default Re: okay guys, i need your advise....oil cooler?? (sporkcrx)
oil coolers really arnet needed on our hondas i have had a temp gauge on mine for about 2 years. oil loses it's viscosicity at about 230 degrees for normal cheap oil and around 300 for synthetic my car is turbo and i road race, no cooler and i have never seen it above 210 on a very hot day that is with a h22 at 18 psi.
if anything you will lose power and flow due to restriction
Old 05-14-2003, 12:48 PM
swrdply400mrelay's Avatar
My friend got an oil cooler, and his oil temps are almost 50 degrees cooler. He used to see oil temps around 230 F in his H22 with a GReddy kit.
Old 05-15-2003, 12:26 AM
sporkcrx's Avatar
Default Re: okay guys, i need your advise....oil cooler?? (forcefed)
Does your h22 have a stock oil cooler though? I've heard of some ITR road racers seeing oil temps near the 300's Guess I'll just use a temp gauge and see what it reads and judge from there if I need it. Good info on the temps that oil breaks down at
Old 05-15-2003, 05:03 AM
MiraiZ's Avatar
how yoo doin'
um..oil coolers = drop in pressure as well
Old 05-15-2003, 06:10 AM
b16supertuner's Avatar
Default Re: okay guys, i need your advise....oil cooler?? (MiraiZ)
drop in pressure from an oil cooler can easily be resolved by using a small honda oil filter.
Old 05-15-2003, 06:33 AM
turbochic's Avatar
Default Re: okay guys, i need your advise....oil cooler?? (b16supertuner)
as for the drop in pressure couldnt I just add more oil to the car?
Old 05-15-2003, 07:13 AM
KCHybrid's Avatar
FYI h22's do have stock oil coolers.
Old 05-15-2003, 08:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmaxturbochic &raquo;</TD></TR><TR><TD CLASS="quote">as for the drop in pressure couldnt I just add more oil to the car?</TD></TR></TABLE>
Well you will need to because of the oil cooler. But you can also use a slightly thicker oil to increase oil pressure.
fmaxturbochic: random note, i see in your sig you want to buy a profec B. Check KChybrid's sig - he's selling one.
Old 05-15-2003, 08:49 AM
turbochic's Avatar
Default Re: okay guys, i need your advise....oil cooler?? (swrdply400mrelay)
fmaxturbochic: random note, i see in your sig you want to buy a profec B. Check KChybrid's sig - he's selling one.[/QUOTE]
thanks, already contacted him!!!
Old 05-15-2003, 10:39 AM
SOHC_power's Avatar
Mine gets up to about 230-240 when it is like 100 degrees outside
around 210 on a normal day, but i do a lot of interstate driving, don't know if that matters tho. Check on the greddy oil cooler kit
Old 05-15-2003, 04:26 PM
sporkcrx's Avatar
Default Re: okay guys, i need your advise....oil cooler?? (SOHC_power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_power &raquo;</TD></TR><TR><TD CLASS="quote">Mine gets up to about 230-240 when it is like 100 degrees outside
around 210 on a normal day, but i do a lot of interstate driving, don't know if that matters tho. Check on the greddy oil cooler kit</TD></TR></TABLE>
And this is just on normal driving?? ****, then it'll be hotter on the track.
9SECQTR
07-01-2004 09:37 AM
Want2race
07-03-2003 09:54 PM
onyx00
05-14-2003 06:22 AM
hardboiled egz
11-20-2002 02:55 PM
SPOON_BeIgHtEeNsEe
03-04-2002 05:24 PM
Quick Reply: okay guys, i need your advise....oil cooler??
