OK to REMOVE oil squiters and plug w/ forge pistons on B18C????
Sup guys.... I search "oil squiter" and found this....
"B18C/B16A applications require removing piston squirters.
I plugged the oil squirters in my B18C to help reduce oil consumption. With forged pistons, you don't need the squirters. If the threads in the hole are o.k.-just put a bolt and a crush washer in all of your oil squirter holes."
Can I really do this to my b18c????? I need to know cuz one of my oil squiters are broken and im not sure if a b16a squiters would work. Please give me your opinion if I should just plug all of them or replace them with b16a squiters??? Thanks guys!
IMO, I would keep them.
They help with lubrication, as well as cooling the pistons a great deal. I've only heard of people removing them on race setups for a little more oil pressure for the bearings, and less windage.
Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">IMO, I would keep them.
They help with lubrication, as well as cooling the pistons a great deal. I've only heard of people removing them on race setups for a little more oil pressure for the bearings, and less windage.</TD></TR></TABLE>
I removed them simply because the cooling effect is no longer needed with forged pistons, and the "squirts" sort of giving a resistance effect as the piston goes to the bottom of the combustion stroke, again may be minute different, but I have had problem with squirters than good. (piston skirt knocks the squirter out, busting oil pressure wyyy low..)
stan
stan
Re: OK to REMOVE oil squiters and plug w/ forge pistons on B18C???? (B18C1-Turbo)
[QUOTE=B18C1-Turbo]If the threads in the hole are o.k.-just put a bolt and a crush washer in all of your oil squirter holes."QUOTE]
I would like to see you come up with a bolt to just put in the oil squirter hole. It is an 8mm bolt with a .75 thread pitch. Impossible to find. I just tap the hole to 1/8" pipe thread and install a pipe plug with an allen head.
Squirters are needed only to cool CAST aluminum stock pistons with very little piston to wall clearance.
Re: OK to REMOVE oil squiters and plug w/ forge pistons on B18C???? (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I would like to see you guys come up with a bolt to just put in the oil squirter hole. It is an 8mm bolt with a .75 thread pitch. Impossible to find. I just tap the hole to 1/8" pipe thread and install a pipe plug with an allen head.</TD></TR></TABLE>
Do what I did, I had Tony1 cut the nozzle of the squirter, and weld it shut. I still use the same bolts but the nozzle is cut where it starts.
stan
stan
Re: OK to REMOVE oil squiters and plug w/ forge pistons on B18C???? (Flamenco-T)
your b16 oil squirters are the same. plug them if your running forged pistons. take some wire crimpers and squeeze the end shut. nick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">[QUOTE=B18C1-Turbo]
Squirters are needed only to cool CAST aluminum stock pistons with very little piston to wall clearance.</TD></TR></TABLE>
Is it a bad thing to keep them with forged pistons?
I stand corrected.
I stand corrected.
garados
05-02-2003 01:06 PM
