OK to bead blast compressor housing/turbine blades?
I am going to start rebuild my dsm t25 next week and had a few qeustions about cleaning it up. Is it ok to bead blast the trubine blades to get all of the crap off of them, and also how about the hot/cold side housings?
Re: OK to bead blast compressor housing/turbine blades? (vtecrx)
Housings are fine. I just had mine done so I could send the compressor housing to get polished, and the bearing and turbine housing to get hi-temp coated by HPC. I am not sure on the blades, but I would assume you could do a great job by doing some detail work.
If you call Gary at http://www.Turbocity.com he can let you know for sure. That guy knows his stuff!
