Oil on a spark plug
I was driving down the road, and I felt the plug foul, so I pulled it and found oil on my plug. Whats Wrong??
Have you done a compression test?
I just picked up the car on friday with 80,000 on the engine that was built by a shop with a good rep. There should be no reason to why the walls, or rings are weak.
Re: Oil on a spark plug (motormike40)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormike40 »</TD></TR><TR><TD CLASS="quote">I was driving down the road, and I felt the plug foul, so I pulled it and found oil on my plug. Whats Wrong??</TD></TR></TABLE>
Laff! You felt the plug foul.... <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormike40 »</TD></TR><TR><TD CLASS="quote">I just picked up the car on friday with 80,000 on the engine that was built by a shop with a good rep. There should be no reason to why the walls, or rings are weak.</TD></TR></TABLE> ... put your beliefs in the trash until you get a compression tester. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">Have you done a compression test?</TD></TR></TABLE> DO IT |
