Oil restrictor needed for Greddy TD05H-18G turbo?
Hey guys, I'll be running a -4an line to a Greddy TD05H-18G without a restrictor. I didnt want to use the line that came with my used Greddy kit, since the one I had was in less than ideal shape. My engine puts out 80 psi of oil pressure at anything over 3000rpm and 25 psi at idle. thanks~!
[edit] did more searching, and people have said that Greddy turbo's have restrictors built in...how can I verify that my turbo has a restrictor in there? i believe my turbo was taken apart for inspection purposes, then put back together after everything was found to be in good shape.
Re: Oil restrictor needed for Greddy TD05H-18G turbo? (Spec R)
The restrictor is right in the chra...It's not possible to remove it, it's part of the casting. If you look directly down where the feed line attaches, there's a hole...that's the restrictor.
Re: Oil restrictor needed for Greddy TD05H-18G turbo? (99blusi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blusi »</TD></TR><TR><TD CLASS="quote">The restrictor is right in the chra...It's not possible to remove it, it's part of the casting. If you look directly down where the feed line attaches, there's a hole...that's the restrictor.</TD></TR></TABLE>
nice. thanks for the help.
