Oil pressure too low for b series vtec?
Had an oil change recently. used mobil 1 15w50 and older type honda filter (i've always been using that type of filter). now, my reading are lower than usual.
it still goes up to ~80psi sometimes when i accelerate but settles down to 69-71psi at 4krpm and higher. oil is still fresh.. i can't believe that oil can be that thin so i'll try to change the filter.
my readings with shell 5w40 were 72-75psi at 4krpm and higher.. what gives?
anyone else using mobil 1 15w50, what type of engine and filter
Re: Oil pressure too low for b series vtec? (vtec.dc2)
In the manual, oil pressure should be at the minimun of 50 psi at 3000rpm. What is your oil pressure at 3000rpm?
Re: Oil pressure too low for b series vtec? (porsche997)
im not sure if its lower at 3k rpm so i'll check, i normally just pay attention to idle and 4krpm cause thats where it settles down at 72-75psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by porsche997 »</TD></TR><TR><TD CLASS="quote">In my lsvtec motor, it idles a 20psi and 62psi at 3000rpm. I have no problem with vtec kicking in.</TD></TR></TABLE>
my vtec works and everything.. only time i had this low of pressure when i ran 5w30 during engine break in.. i'll be switching oil filter first, hopefully that will do it.
It takes like 20 minutes of *real* driving until oil pressure stabilizes.
when you are up in the 60+psi range, a few PSI of oil pressure really doesn't matter. There is a regulator/bypass in the oil pump to keep pressure from getting over 6bar anyways. When it gets that high it cuts it off and there should be a max of 5bar oil pressure (~75psi). i.e, at high RPM or low RPM when the motor is cold/relatively cold.
Re: Oil pressure too low for b series vtec? (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin »</TD></TR><TR><TD CLASS="quote">It takes like 20 minutes of *real* driving until oil pressure stabilizes.
when you are up in the 60+psi range, a few PSI of oil pressure really doesn't matter. There is a regulator/bypass in the oil pump to keep pressure from getting over 6bar anyways. When it gets that high it cuts it off and there should be a max of 5bar oil pressure (~75psi). i.e, at high RPM or low RPM when the motor is cold/relatively cold.</TD></TR></TABLE>
yes, i'm reffering to after 20 minutes of driving, after pressure settles down. i warm up the car for 10-15 minutes anyway but it still takes few miles until pressure settles down. it normally would be 5.1-5.3 bar or kg/cm2, but in my latest runs it was more like 4.8-4.9 kg/cm2 below 5 kg/cm2 mark.
As long as you're not seeing like 35-40psi @ 3000rpm, you're fine.
w/ stock gsr using 10w30 in hot weather I see about 60psi @ 3000rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin »</TD></TR><TR><TD CLASS="quote">As long as you're not seeing like 35-40psi @ 3000rpm, you're fine.
w/ stock gsr using 10w30 in hot weather I see about 60psi @ 3000rpm.</TD></TR></TABLE>
i replaced the filter and that was a waste of good filter they don't make anymore - poh-305 made in US. mobil 1 15w50 supposed to have HTHS of 4.7? at least thats according to manufacturer.
i'm showing average reading of 4.2kg/cm2 at 3k rpm.. i guess thats about 60psi..
Yeah i still have some of the old filters floating around. I bought like 10 a couple years ago. I also have a bunch of the new mini ones... don't like them.
i bought like 120 or 150 of them as they were being discontinued. this is not just for one car, but should last for several years
Jason C SBB
05-26-2005 02:57 PM
Si Erik
26
09-08-2003 06:02 AM
