Oil Pressure Gauge vs. OEM Oil Pressure Light
having trouble with oil pressue and what not on a boosted d15b...
getting about 15-20psi at a warm idle, and 40-50psi crusing at 2500-3000rpm according to my electronic oil pressure gauge. i know the stock oil pressure light will come on really low, like at 5-7psi, but the light now comes on with the readings above^^. not driving it at all because i dont want to risk the bearings, but just wanna see what other's input is. |
Re: Oil Pressure Gauge vs. OEM Oil Pressure Light (jdmsiR20)
Post up some pics of how you have everything T'd, chances are something got fouled up with the factory sensor.
Re: Oil Pressure Gauge vs. OEM Oil Pressure Light (a1320addict)
single T, from a golden eagle sandwich
Reset the ecu, see if it goes away. If not I think you'll be ok, I'd trust the gauge over the "idiot light" anyday.
i thought so too. at the moment i still wont drive it, just until im absolutely sure. not worth risking it, right?
i'll get pix up today https://honda-tech.com/forums/images/smilies/emthup.gif |
Pics for sure
i dont think he wanted a pic of ur car............................
Re: Oil Pressure Gauge vs. OEM Oil Pressure Light (deca)
i would trust the gauge over the light
Re: (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict »</TD></TR><TR><TD CLASS="quote">Reset the ecu, see if it goes away. If not I think you'll be ok, I'd trust the gauge over the "idiot light" anyday.</TD></TR></TABLE>the ecu doesnt turn the oil light on/off. https://honda-tech.com/forums/images...es/emdgust.gif
that light is triggerd by a ground. check to see if you have a short on the sensor wire. if i comes on really dim, it could be a bad gauge cluster or bad ground on the cluster.
Re: (jameelrose)
I know the ecu won't reset the light....obviously he has an electrical problem somewhere, so it makes sense to start with the simple things.
Re: (a1320addict)
OEM sending unit might be bad.
