oil light on boosted 00 gsr
when i start up my car the oil light stays on for a second or two. i just changed the oil and filter and i do it every 2000 to 2500 miles and im using mobile 15w 50. also when i pulled the dipstick out it smelled kinda burnt. any input would be great.
Re: oil light on boosted 00 gsr (VNTEC)
no its not leaking. i have an oil pressure gauge and it idles between 20 and 25 psi and peaks out around 75 psi.
Re: oil light on boosted 00 gsr (gsr2187)
Mine does the same thing but that seems normal to me because both of my GSR's did that on a cold start. It takes a second or two for the oil to reach the oil sending unit. I wouldn't worry about it too much.
If you're driving and the light comes on...that's a whole different story. It'll come on when your oil level/pressure is very low and most times its already too late by the time you pull over.
