oil leaks suck!
well, i just got finished working on my oil line leak on my oil pan. i applied a light coat of JB weld. heard it works better than the weld compound. it seems like it would work better, considering it had better consistency and not so dry and claylike. lets see if it works out... too many oil spots wherever i park.
one opinion i wanna get from you guys, though... i noticed that im starting to get a noticable headgasket oil leak. i want to prevent any further damage to the engine by either replacing it with an inlinepro headgasket or a blockgaurd. what do you recommend? i know its better to consider getting a new block... its quite costly. http://images.zeroforum.com/smile/emcrook.gif |
Re: oil leaks suck! (dlplayboy)
I say get a block guard, it sounds like that will solve all your problems.
Re: oil leaks suck! (Phantom)
ROFL.
Blockguard fo sho! That piece of aluminum works wonders for everything that's bad about honda Engines.... |
Re: oil leaks suck! (SiR Kid)
Blockguard for a headgasket leak???
Remove the head and use some copper spray($6-7 at most auto stores) |
actually forget about any special headgaskets. Just go to the dealer and pick up a new factory headgasket for the car and slap it on. You dont want to lower compression at all, plus the factory one is probably cheaper. Forget about the blockguard.
Re: oil leaks suck! (TurboInteg95)
actually forget about any special headgaskets. Just go to the dealer and pick up a new factory headgasket for the car and slap it on. You dont want to lower compression at all, plus the factory one is probably cheaper. Forget about the blockguard. |
go get beer can and make a gasket whit it
Re: oil leaks suck! (rickC1)
the block guard prevents the cylinder walls from moving under high pressure, so how is this going to help an oil leak? unless he doesn't have a block guard already and the cylinder walls are some how moving the head gasket around!
Re: oil leaks suck! (CovertFI)
actually, a blockguard would be an addition to the new head gasket. just wondering if i should go with an inlinepro or some other brand instead of stock. im just wondering what blockguards are good. got some opinions before... but never really narrowed it down to the best one to get.
If your gonna get a blockguard, go with STR. Headgasket go with stock or cometic both good and cheap.
Re: oil leaks suck! (Ray)
blockguard goes on top of the cylinder walls, and headasket goes between the head and block
it's two different thing get a head gasket to solve your leakege |
Re: oil leaks suck! (Flamenco-T)
blockguard goes on top of the cylinder walls, and headasket goes between the head and block it's two different thing get a head gasket to solve your leakege |
What about your head bolts are those stock? how much boost you running? I have had this problem before with two customers, change the gasket and used arp bolts and it never happend again.
Re: oil leaks suck! (blueciv69)
What about your head bolts are those stock? how much boost you running? I have had this problem before with two customers, change the gasket and used arp bolts and it never happend again. |
one thing.. is that the last head stud on the left is broken, so i pretty much have to tap a new stud. shop broke it during the install and i was too anxious to drive my car that i just took it that way. http://images.zeroforum.com/smile/emhammer.gif |
Re: oil leaks suck! (bQQsted hybrid)
yeah, I say you found your problem. Stock head bolts are<edit> known to stretch with boost making the head gasket vunerable to blow out. Happend to me all the time.
[Modified by blueciv69, 4:46 PM 4/2/2002] [Modified by blueciv69, 5:53 PM 4/2/2002] |
yeah, I say you found your problem. Stock head bolts are know to stretch with boost making the head gasket vunerable to blow out. Happend to me all the time. [Modified by blueciv69, 4:46 PM 4/2/2002] i figured the headgasket was gonna go anyway. i boost the shiznit out of it and i have 131,000+ miles on my motor. i expected it to happen sometime. ive been boostin hard for 1year and a few months now... time to start upgrading things. thanks for the info, guys. http://images.zeroforum.com/smile/emthup.gif http://images.zeroforum.com/smile/emwink.gif |
| All times are GMT -8. The time now is 05:32 AM. |
