oil leak woes
oil leak woes
on my turbo gsr, i have had non stop oil leakproblems. The oil leaks and burns off on the downpipe, and leaving under my car coated with oil.
it appears its coming from the black box where the pcv valve is, i replaced the o ring for it but its still leaking.
I think other guys are having problems with oil leaks, wat is everyone doing to solve these issues.
Re: oil leak woes (vtecluder97)
whats ur pcv set up like? because sometimes with stock pcv's arent good enough to relieve crank case pressure, my turbo ls always had a pan gasket leak and it could of been from the pressure building up. You need a good catch can set up if u dont have one yet.
hatchedeg
06-29-2006 09:02 PM
