Oil Feel Line Leaking Oil
it's a TD05, the Sohc greddy turbo
I seen oil leaking from the oil feed line that is going into the turbo...
what can I do to fix this??
thanks
thanks
Re: Oil Feel Line Leaking Oil (Kimbo)
I had the same problem with my greddy turbo. i just replaced the entire line and fittings. Are you sure your turbo is a tdo5? i thought the sohc came with td04.
Here is my write up on it. https://honda-tech.com/zerothread?id=319213
Re: Oil Feel Line Leaking Oil (DeepSi)
This happened to me last week. I took the car in cuz it was smoking alot. They found the leak, it was the oil return line so they replaced it with a steel braided one. I picked the car up on monday and drove a few blocks, still had smoke and burning oil smell....so I looked under the car and had a puddle of oil. Took the car back to the shop and was told today that it was the oil feed line, it was leaking from the fittings and the line itself was cracked. They are replacing the line and the fittings now.
CivicDude2k4
09-05-2006 08:24 PM
