oil drain line pics, where should I locate it?
drain flange is now pointed down and I have -10 AN lines and 2 45 degree elbows to play with
Re: oil drain line pics, where should I locate it? (yusoslo)
down pipe will be routed under the oil pan so I was thinking of putting it right behind the down pipe at the highest level possible
with one 45 pointed sideways to the pan and the other sideways and upward toward the turbo
I want to be MADE into Ice-T
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yusoslo »</TD></TR><TR><TD CLASS="quote">
hey thats my garage!!!
bump for my buddy BJ
contact stan because I think you should change out your male to male with a 45 swivel.
http://www.fast-turbo.com/oilreturnassembly.html
Re: oil drain line pics, where should I locate it? (FredoSP)
already have 2 45 swivels. And a 1/2npt to -10 an fitting from the turbo to the 45 and a -10 an sadwich setup on the oil pan with nylon washers
Yeah Im Stan he helped me with mine so I could get the right angle. Haven't had any problems at all.
Re: oil drain line pics, where should I locate it? (FOrSfEd)
i put mine in the skinnier part of the pan, over to the left looking at it. no ned to worry about DP clearances.
Landon
Landon
Re: oil drain line pics, where should I locate it? (boosted_dc2)
so does anyone else agree with the skinny mounting point?
That is what I was going to go with first but was told differently by the performance shop in my area.
If it's not to late; it's FAR easier if you mount the turbo the other way. Then the DP, charge pipe and oil drain don't cross. and you can just throw an air filter on the turbo in most cases.
ya the skinny part is fine.
Re: oil drain line pics, where should I locate it? (Bailhatch)
well I thought most turbo kits have the compressor on the passenger (left hand side) or the engine bay?
2kdrift
01-28-2017 06:15 PM
igo4bmx
03-14-2004 06:23 AM
