Oil catch can from valve cover breather (Turbo)
After doing some research im still a bit confused on weather I can run this oil catch can setup on my turbo d16Y7 (~9 psi):
route the intake part of the catch can from the valve cover breather and the out part to the piping before the turbo (between the turbo and air filter) I believe this should work, but I was worried that the turbo would suck in oil from the catch can? any advice is appreciated, I would like to avoid using the PCV system |
Re: Oil catch can from valve cover breather (Turbo)
