Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Forced Induction
Reload this Page >
Oil Catch Can Setup for VTEC engines w/o silly -10AN Valve cover Vents
Old 05-29-2019, 11:59 AM
  #26
Default Re: Oil Catch Can Setup for VTEC engines w/o silly -10AN Valve cover Vents
So on the b18b valve cover would I plug the PCV valve number 1 and route the hose from hole 2 like you have?
dlx111 is offline
Old 05-30-2019, 02:01 AM
  #27
Moderator
TheShodan's Avatar
that's correct. the other check valve will not fit there.
TheShodan is offline
Old 05-31-2019, 05:43 AM
  #28
any recommendations on what to plug that hole with?
dlx111 is offline
Old 05-31-2019, 09:14 AM
  #29
Moderator
TheShodan's Avatar
I'm sure you may be able to finagle some coin-sized service grommet. Otherwise, unfortunately, nothing comes immediately to mind.
Old 05-31-2019, 02:41 PM
  #30
Glue coin to hole, got it.
dlx111 is offline
Old 06-02-2019, 08:08 AM
  #31
Opinion on drainback to oil pan vs the block plug? I have a moroso pan with an option for drainback.
Also do you happen to know the size of the two freeze plug adapters? I keep seeing some that are 28mm listed as B series and some as 38mm listed as B series.
dlx111 is offline
Old 06-02-2019, 07:22 PM
  #32
Moderator
TheShodan's Avatar
I would go back to the block to allow the oil to disperse above the windage tray . oil pan would experience disruption. I wouldn't drain back there
  • Ask a Question
Question Title:
Description:
