Ohisofly’s 91 Si project – 700hp or bust - Page 3 - Honda-Tech - Honda Forum Discussion
Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Forced Induction
Reload this Page >
Old 03-07-2019, 10:45 AM
  #51
ohisofly's Avatar
Default Re: Ohisofly’s 91 Si project – 700hp or bust
Originally Posted by DaX View Post
Bummer. I had to do mine twice too. The can of wrinkle paint definitely had enough to do 2 valve covers though, if using their prescribed method of 3 thick coats.
Yea I had enough to redo mine and probably enough to do another valve cover too. I’m pretty happy with how it came out overall
It’s been a little while but here’s what I’ve been up to
Measured the valve to valve clearances
Have plenty of room for adjustment
Had to file down a washer to get the degree wheel to fit properly
Installed bbs to lock vtec, used check valve springs, and bent a coat hanger to reference against the degree wheel. After putting the timing belt on and setting up the dial indicators I degreed the cams and measured piston to valve clearances
I've seen various figures on what's considered safe minimum p2v clearance but even going conservative with a minimum .100 or .080 still allows for plenty of room to play with cam adjustment. Degreeing them put it at -1, -1 which seems reasonable given the decked head & block
Then I started putting together the head, OEM valve seals
Supertech 85 lb springs, supertech steel retainers, blox lmas
Ferrea 6000 std valves and ferrea keepers
Head ready to bolt down
ARP headstuds
Bolted down
Delta 272 cams
Redoing the valve cover
Not perfect but it’ll do
New timing belt covers & gaskets
I accidentally got the wrong bottom cover so had to shave the bottom a little bit. It doesn’t sit flush against the oil pump at the bottom but close enough
Covers on
Started working on my transmission again, the youtube video I was following had the orientation of the 3/4 hub & slider upside down, causing everything on the mainshaft to be off a little bit. The case ultimately was maybe 2 or 3mm from closing
You can see the bearing at the top of the mainshaft isn't down the whole way
The hub & slider being upside down caused this needle bearing to be off, hence pushing up everything on the mainshaft
Took everything apart and cleaned it since it’s been sitting for maybe 6 months or so
All back together, replaced the 5th gear cuff mainshaft bearing as it was a little rough
I still need to find the c-clip that holds the countershaft to the case and the axle seals but it’s almost finished
Skunk2 70mm throttle body
Installed with a thermal gasket
Speedfactory 4bar map sensor
This is how it’s sitting right now
Currently waiting on new vtec solenoid gaskets and need to find the transmission seals that I have somewhere. Hopefully in the next few weeks I’ll be able to get the motor and trans dropped in so I can finish wiring the engine bay and start working on the turbo setup. Planning on a divided top mount manifold
ohisofly is offline
Old 03-08-2019, 02:54 AM
  #52
O.G. triple O.G.
NVturbo's Avatar
awesome work, man. Always wanted a CRX but finding one in decent condition is nearly impossible.
NVturbo is offline
Old 03-08-2019, 03:29 AM
  #53
2x0
2x0's Avatar
Lookin good! Subbed
2x0 is offline
Old 03-08-2019, 04:02 AM
  #54
Txdragon's Avatar
Looking good! I still cringe when I see a broke down transmission.
Txdragon is offline
Old 03-08-2019, 06:32 AM
  #55
LightningTeg's Avatar
Why? Its amazing how simple it is once you get it apart.
LightningTeg is offline
Old 03-08-2019, 06:57 AM
  #56
2x0
2x0's Avatar
I'm sure, like many things, it's only scary the first time you do it.... I, too, have yet to crack one open. It's only a matter of time.
2x0 is offline
Old 03-08-2019, 09:20 AM
  #57
Txdragon's Avatar
<br /><br />
Txdragon is offline
Old 03-08-2019, 09:22 AM
  #58
Txdragon's Avatar
It could be. I am actually looking locally for a throw away transmission to use like a med student uses a cadaver.
Txdragon is offline
Old 03-08-2019, 09:58 AM
  #59
Jeff Evans has a 3 part video on you-tube on how to disassemble and reassemble B series trans
Old 03-08-2019, 10:10 AM
  #60
maxwellmercer's Avatar
It's intimidating at first but, like others said, it's very simple once you get your feet wet. I personally lay every piece out in order as I take it out. Makes life a little easier! Its really cool once you get comfortable.
maxwellmercer is offline
Old 03-08-2019, 11:35 AM
  #61
ohisofly's Avatar
Lookin good! Subbed
Thanks guys, I'm finally starting to make some good traction with this thing
This was the first transmission I've ever split the case on and it was definitely intimidating at first but it eventually starts making sense. The main negative for me was you won't find nearly as much info about rebuilding a b series tranny as a b series engine, so if you get stuck as in my case it can be a little tricky. Blown up diagrams of how everything stacks on the countershaft and mainshaft ended up being my best friend
ohisofly is offline
Old 03-12-2019, 06:31 AM
  #62
ohisofly's Avatar
I don't need this coolant port anymore
Welded it shut
Don't need this small one on the top either
Only the port nipple itself was steel, the rest is aluminum. Forgot to get an after picture but it doesn't look good. It's watertight though which is all that I really care about
Starting to look like an engine. Mocked up the fuel filter, fuel rail, fuel pressure regulator and injectors. Ended up ordering some fittings I'll need to complete the fuel lines but it's looking good overall
Ordered a new distributor clip because this one is toast
New vtec solenoid gaskets
I ordered new axle seals for the transmission, should be able to bolt together the case this weekend. Once that's finished just need to put on the twin disc and drop it in. I ordered a bunch of pipe for the turbo manifold which should be here next weekend as well
ohisofly is offline
Old 03-12-2019, 07:02 AM
  #63
Not crazy about the filter hanging off the fuel rail like that. Vibration and fuel fittings scare me lol
Old 03-12-2019, 07:36 AM
  #64
Agreed, aluminum fittings plus vibration is recipe for disaster. I had a buddy mount his FPR like that and let's just say it didn't end well.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
