Official Injector Resistor Box Install......56k, Buy Broadband.
#51
Re: Official Injector Resistor Box Install......56k, Buy Broadband. (J2turbo21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 »</TD></TR><TR><TD CLASS="quote">
From the pic i did the bottom left,top left,2nd top left,and last top right.What did you guys do?</TD></TR></TABLE>
like this?
anyone else?
like this?
anyone else?
#52
Re: Official Injector Resistor Box Install......56k, Buy Broadband. (cornhusker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cornhusker »</TD></TR><TR><TD CLASS="quote">
like this?
anyone else?</TD></TR></TABLE>
Mine was the 4 right ones. (Top Right, Bottom Right, 2nd Top Right 2nd Bottom right)
Just check continuity!!!!
like this?
#53
Re: Official Injector Resistor Box Install......56k, Buy Broadband. (ladysman)
I got a reply from Doug @ Hondata and he said he would check out this thread.
#54
Re: Official Injector Resistor Box Install......56k, Buy Broadband. (Dee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee »</TD></TR><TR><TD CLASS="quote">I got a reply from Doug @ Hondata and he said he would check out this thread. </TD></TR></TABLE>
have you heard back from doug yet?
also, to check continuity did any of you guys have to cut/strip the wires at the injectors to get a signal? what did you use? thanks.
#55
I just removed the cover on the distribution block and stuck the the red stick in there and the black one on the injector clip.
#56
also, to check continuity did any of you guys have to cut/strip the wires at the injectors to get a signal? what did you use? thanks.</TD></TR></TABLE>
No need to strip. Just take off the injector clip and put one side in the clip (Yello/black wire side) and the other in the distribution block until it reads on the voltmeter (or beeps like mine does).
#57
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote">
No need to strip. Just take off the injector clip and put one side in the clip (Yello/black wire side) and the other in the distribution block until it reads on the voltmeter (or beeps like mine does).</TD></TR></TABLE>
doh ( on me). dang, now dont i feel like a turd. i guess two heads are better than one. (or in my case half). i dunno why i didnt think of that. looks like i have a little project to do. thanks.
#58
just got done checking continuity tonight. mine are exactly the same as hondata's website. hmmm, maybe it is different between different models? anyone wanna help figure this out? anyways, i am on an vtec harness (ex). what about everyone else? and if there is nothing related to the different models, **** it, check continuity, it only takes 5 minutes (10 if you are slow like me). cuz if i can do it, anyone can.
#60
Re: (-Bionic-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- »</TD></TR><TR><TD CLASS="quote">On my resistor box I have 5 wires, four black and a red. I was wondering what that fifth wire could be? Is it for ground?</TD></TR></TABLE>
Did you not look at the beginning of my post? Look at step 5.
#61
like this?
back from the dead, but i think thats what mine looked like...but my guess, is they are all joined to a +12v ignition, the people who make the connector dont put them in any particular order.
like this?
#62
like this?
like this?
#64
Re: (CIVIC4DOORMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIVIC4DOORMAN »</TD></TR><TR><TD CLASS="quote">i have a 91 si and it has the resistor box already.am i ok to run 450's or do i have to do something else?</TD></TR></TABLE>
You are fine.
You are fine.
#65
Re: (ladysman)
You have lost me completely. You don't need a power source for the resistor pack.
This is also for DropSquadCivic + H23vtecEG:
The power source is what is hooked up to the red wire (the 4 injector hot wires) and the resistor box limits the current that flows from the hot, to the 4 injectors. The ECU GROUNDS the injectors to fire them, in sequence, so i beleive.
#67
Re: (allstokhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allstokhonda »</TD></TR><TR><TD CLASS="quote">do all resistor boxes look the same. j/w... also where can I find one. I think I might need one. </TD></TR></TABLE>
No, and I have several. PM me for an unfair price.
#68
Re: (slashDEVslashNULL)
Sorry, I don't quite follow. I am going to be doing this soon and I want to make sure I don't screw it up. Tell me if I am right with the following. I take a wire from the distribution block, and find the injector it corresponds to. Then I solder one wire from the resistor box inbetween right? Like basically a tap. Does a certain wire on the resistor box go to a certain injector wire? or does it not really matter? Once I have that done, what do I solder the 5th wire to? Thanks
David
David
#69
Re: (n1neb4ll)
are all honda resistor boxes the same? if so, a pinout chart would be of great help!
edit: nm! i should have done more research! http://hondata.com/techinjectorwiring.html (chart is said to be wrong)
Modified by jdmsiR20 at 7:10 AM 12/5/2003
#70
Its simple...once you find the 4 blk/yel injector wires, cut them, then the red wire from the box is soldered together with the 4 wires coming from the ecu or main harness from the inside of the car, and the other 4 wires from the box are soldered to the yel/blk wires leading to the injectors(one wire from the box to one wire for an injector)
#71
Re: (ph8ed4life)
so it doesn't matter which wire is soldered to which wire, just that all 4 wires from the ecu are soldered to ONE wire (one wire connected to all 4 wires) and then the other 4 wires are soldered to the injector wires (can be totally random if you want) correct?
#72
Re: (n1neb4ll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1neb4ll »</TD></TR><TR><TD CLASS="quote">so it doesn't matter which wire is soldered to which wire, just that all 4 wires from the ecu are soldered to ONE wire (one wire connected to all 4 wires) and then the other 4 wires are soldered to the injector wires (can be totally random if you want) correct?</TD></TR></TABLE>
Yes.
Yes.
