oem honda headgasket or cometic?
Re: oem honda headgasket or cometic? (the.hamburglar)
https://honda-tech.com/zerothread/1994089
I'm in the same boat.
Never had a problem with OEM, both D and B series. Most people will tell you the same. Cometic gaskets seem to be hit or miss. Some can't get them to seal, while others run them with no problems. I'd say run an OEM gasket if you can, unless you need a weird size or something.
Re: (the.hamburglar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar »</TD></TR><TR><TD CLASS="quote">wait a second, can i get an oem with an 81.5mm bore?</TD></TR></TABLE>
The stock one will work for 81.5mm.
