OBD2 to OBD1 Conversion
What is necessary to do this conversion. Just the wire harness and ECU or do I have to get an OBD1 distributor too?
Re: OBD2 to OBD1 Conversion (c2nap)
I just did it on my car, all you need is a conversion harness and an obd1 ecu.
Rob |
Re: OBD2 to OBD1 Conversion (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy »</TD></TR><TR><TD CLASS="quote">I just did it on my car, all you need is a conversion harness and an obd1 ecu.
Rob</TD></TR></TABLE> That is correct. |
Re: OBD2 to OBD1 Conversion (Blown90hatcH)
does it matter which ecu i get? i have a d16y7. can i use p28?
Re: OBD2 to OBD1 Conversion (khoalie)
match the ecu to the motor
Re: OBD2 to OBD1 Conversion (Boostfedb18c1)
so i should get the obd1 lx/dx ecu p06 correct
sorry for such newb q's |
if ur runing a none vtec motor such as a d16y7 then yes
| All times are GMT -8. The time now is 04:05 AM. |
