Nut4vette's EM1 Turbo B18C5 Progress Build
https://cimg1.ibsrv.net/gimg/honda-t...ba7a76c12.jpeg https://cimg0.ibsrv.net/gimg/honda-t...a3e9144d3.jpeg just rebuilt my block eagle rods wiesco 9.6:1 pistons oem oil and water pump,my head is in the shop now, had a cracked valve guide so it’s getting super tech guides, Ferrea 6000 intake valves and comp plus exhaust valves, Sk2 pro 1 cams, sk2 valve springs, sk2 titanium retainers, sk2 lmas, oem valve seals, and sk2 cam gears, tons of other stuff done to my car too but will get to all that later |
re: Nut4vette's EM1 Turbo B18C5 Progress Build
Goals? Intended use?
Looks good, but let us know more about what you're up to bruh. |
Well I didn’t sleeve my block so I am gonna keep it around 500whp, I have a spare jdm type r block I’m gonna send out some day and have sleeved then swap the two, it’s gonna be driven on street mostly, maybe tracked one weekend a month. Gonna be going with a sheepey top mount a/c compatible setup with a Garrett GTX3682r on e85. Gonna take my time and do it right, maybe have it ready spring of next year |
When it was still drivable, it’s in pieces in the garage now https://cimg7.ibsrv.net/gimg/honda-t...a997c9fd7.jpeg |
Re: Em1 turbo b18c5 build
Originally Posted by nutz4vette
(Post 51639413)
Well I didn’t sleeve my block so I am gonna keep it around 500whp, I have a spare jdm type r block I’m gonna send out some day and have sleeved then swap the two, it’s gonna be driven on street mostly, maybe tracked one weekend a month. Gonna be going with a sheepey top mount a/c compatible setup with a Garrett GTX3582r on e85. Gonna take my time and do it right, maybe have it ready spring of next year |
Re: Nut4vette's EM1 Turbo B18C5 Progress Build
(Post 51639163)
just rebuilt my block eagle rods woes I 9.6:1 pistons oem oil and water pump,my head is in the shop now, had a cracked valve guide so it’s getting super tech guides, Ferrea 6000 intake valves and comp plus exhaust valves, Sk2 pro 1 cams, sk2 valve springs, sk2ti retainers, sk2 lmas, oem valve seals, and sk2 cam gears, tons of other stuff done to my car too but will get to all that later |
(Post 51639413)
Well I didn’t sleeve my block so I am gonna keep it around 500whp, I have a spare jdm type r block I’m gonna send out some day and have sleeved then swap the two, it’s gonna be driven on street mostly, maybe tracked one weekend a month. Gonna be going with a sheepey top mount a/c compatible setup with a Garrett GTX3682r on e85. Gonna take my time and do it right, maybe have it ready spring of next year For a street car it would be best to choose components geared towards a faster spool and better mid-range power. |
Mini ram and 30r or similar sized if you want to have any type of responsiveness on the street. A top mount and 35r is going to have a light switch power band, gonna be lag lag lag, instant wheel spin, banging limiter while you watch the tail lights of the car you’re racing pull away lol. I’m just saying unless this is a straight up drag car there are much better options available. clean car btw 👍🏼 |
I have a spare jdm type r block that I’m sending off to have sleeved, the real goal was 700-800whp to begin with but couldn’t get the approval for another $1200+ at the time from the wife with my first child on the way, when I get the sleeved block it will be a straight drag car and the unsleeved block is going in a eg hatch, the head already has sk2 pro1 cams, they were in it when I got the engine, it made tons of racket from the stock lmas so I swapped them out |
So far Block mods: B18c5 Eagle rods Wiesco 9.6:1 pistons Acl main bearings King rod bearings Ati super street damper New oem water pump New oem oil pump New oem gaskets and sensors Arp head studs Innovative 80a mounts Hasport torque mounts Head mods: B18c5 Supertech valve guides Ferrea 6000 intake valves Ferrea comp plus exhaust valves New oem valve seals Sk2 pro series dual valve springs Sk2 ti retainers Sk2 Lmas Sk2 pro 1+ Cams Sk2 cam gears Bdl fuel rail Hondata intake mani gasket Trans mods: B18c5 Comp stage 4 6 puck unsprung kit Russell as clutch line Exedy master and slave cylinder kit Suspension mods: Progress cs2 coilovers Function7 rear lcas Sk2 lca hardware Hardrace upper control arms front and rear Hardrace trailing arm bushings Hardrace rear toe kit Asr rear brace 24mm sway bar kit Spoon front and rear sway bars (legit) Buddy club ball joints Insane shaft 500hp axles New Koyo wheel bearings all around Misc mods: Ktellar 3” mandrel exhaust Vibrant turbo muffler and resonator Mishimoto radiator, fan, and hoses Chipped p28 on neptune Buddyclub p1 wheels (white) 205/50/15 nitto bro gens Optima yellow top battery B&Mshort throw |
Future mods: Garrett Gtx3582r with tial v band housing Sheepey a/c compatible t3 top mount manifold sheepey 850hp intercooler sheepey catch can(have) Custom downpipe Custom intercooler piping turbosmart 45mm hypergate (have) tial Q 50mm bov (have) jbtuned full e85 kit Walbro 450lph pump injector dynamics 1300cc injectors Aeromotive fpr(have) omni 4 bar map (have) Aem Air/fuel and boost gauge (have) Defi water temp, oil press, and egr gauges and of course a retune |
Originally Posted by boosted94gsr
(Post 51639910)
I am aware the turbo and mani are overkill for 500whp, But I’m kinda torn on what I wanna do I have the 95 hatch and em1, one is gonna be street and one is gonna be strip, don’t really know for sure which is gonna be which, one will get the non sleeved block and full race ram horn I have with precision 5858 that I have, and the other will be sleeved with sheepey topmount and gtx35r, the eg hatch is farther from being ready and I am dying to drive a somewhat fast car again, my daily is a 17 ct200h f sport so yeah I’m pretty much dying, I had decided the em1 was gonna be the drag car but I’m still very torn that’s why I put the turbo setup as the bigger setup, but it already has the non sleeved block so I may leave it and slap the ram horn on it and make the hatch the drag car, I’m way to indecisive lol |
I was told the pro1s really need at least a 62mm, im tempted to just trade for some stock type r cams |
(Post 51639961)
I am aware the turbo and mani are overkill for 500whp, But I’m kinda torn on what I wanna do I have the 95 hatch and em1, one is gonna be street and one is gonna be strip, don’t really know for sure which is gonna be which, one will get the non sleeved block and full race ram horn I have with precision 5858 that I have, and the other will be sleeved with sheepey topmount and gtx35r, the eg hatch is farther from being ready and I am dying to drive a somewhat fast car again, my daily is a 17 ct200h f sport so yeah I’m pretty much dying, I had decided the em1 was gonna be the drag car but I’m still very torn that’s why I put the turbo setup as the bigger setup, but it already has the non sleeved block so I may leave it and slap the ram horn on it and make the hatch the drag car, I’m way to indecisive lol Don't "Slap on" anything. Think.. |
(Post 51639967)
I’m just torn on which car I want to be my drag car, but yeah with the engine I have I’m trying to utilize those cams and letting them dictate my build, I don’t need to do that, I really like driving my em1, it’s overall a nicer car so I really want to make it my street car, so if I ditch those cams and get stock Itr cams and use the turbo setup I already have, then fab my ic piping and down pipe and get the rest of what I need she will be ready to go way cheaper and quicker, then I can just start fresh with the drag car, this isn’t my first rodeo just so y’all know I come from the dsm world lol, and been working on tuners for a while, but also have had a little of everything, and trust me I won’t just slap stuff together, that’s why I haven’t gotten my bigger turbo or manifold yet, just hadn’t decided for sure yet, and thanks for the input shodan, your a legend bro and been reading your stuff for years |
Originally Posted by TheShodan
(Post 51639760)
If you plant to run anything like a Kelford or GSC-T1 purpose made camshaft, please do not use the spring style LMAs without accounting for tighter valve lash. Or stick to the hydraulic LMAs if you plan to use an aftermarket camshaft like I just mentioned.
Tighter valve lash, any idea how much tighter? Side-note: I've become more and more attracted to the look of the EM1's, and 6th gens in general. I like the look of the car, OP. |
Originally Posted by Chance EG
(Post 51640504)
That's interesting, what have been your experiences with the spring style LMAs on those cams? Last I spoke to GSC they didn't tell me anything special about them, actually stated that it's a toss up whether to use hydraulics or springs. Are the springs known to bind on them?
Tighter valve lash, any idea how much tighter? Side-note: I've become more and more attracted to the look of the EM1's, and 6th gens in general. I like the look of the car, OP. I'll try to expand more in the GSC thread, as I don't want to take this one too far off track.. |
So I purchased a pte 5858 jb. Going to get mini ram or Ramhorn mani, posted the pro1 cams on eBay and they have bids so they should sell. So given my hp goal for this car of 500whp which cams would you all recommend, been researching turbo cams and relevant hp ranges, so just wanting your opinions, are Kelford 176-T or GSC 6015T1 to aggressive? Would I be better off to stick with gsr, itr, sk2 tuner 1, or something totally different? Seems like the Kelford and GSC geared more towards 600+ |
(Post 51652502)
Took everyone’s advice/opinions into consideration and ended up selling the pro 1s and buying tuner 1s, I looked into sheepey built, Klm fab, and speedfactory for thei a/c compatible ramhorn and ultimately went with speedfactory, and that will be paired with a jb 5858 that I got from ht marketplace, so now just need to get turbosmart comp40 or tial mvs 38mm wastegate, and Intercooler, make Intercooler pipes, and a little more fuel components, what you all think? Any input on the parts I still need, gonna get 1300cc injectors and a walbro to 450lph pump, think that will be plenty for 500whp on e85, what about ic, brands you all prefer and all that |
Looking good! I just got my speedfactory manifold a few weeks ago and it is fkn beautiful!
