Re: Not another 2.5-3" downpipe pic (sharkcohen)
Re: Not another 2.5-3" downpipe pic (BoostedSi)
looks nice and clean, way to go
Re: Not another 2.5-3" downpipe pic (SIXTYdashONE)
where can i find that reducer?
So i don't make another topic, what if i built a 3" downpipe that reduced to a 2.5" at the flange? |
Re: Not another 2.5-3" downpipe pic (GraphiteAccord)
where can i find that reducer? So i don't make another topic, what if i built a 3" downpipe that reduced to a 2.5" at the flange? |
Re: Not another 2.5-3" downpipe pic (philo)
where can i find that reducer? So i don't make another topic, what if i built a 3" downpipe that reduced to a 2.5" at the flange? The reducer is a flowmaster unit from summit racing. Why would you want to do a 3 --> 2.5". The only reason we do the upper downpipe portion in 2.5" is so it easily clear the a/c compressor. If your cat and exhaust system is 2.5" I would just do a 2.5" downpipe. I already have some nice 3" tubing laying around that i can use. I plan on a 3" downpipe, then have it connect to a flange with the reducer, then to a flex pipe, then to my cat. Should i just delete the cat with the Flex pipe? I still need a way of putting a cat on though for emissions... |
if only I can post mine....
mine is strictly function over fashion, I flared it from 2.5" to 3" right after it clear the AC compressor after the firs bend off of the turbine housing... agian, $30 home depot welder, boring ass sunday and a shitload of piping laying around can turn you into a freak like me... https://honda-tech.com/forums/images...s/emsmilep.gif stan |
Re: Not another 2.5-3" downpipe pic (Flamenco-T)
if only I can post mine.... mine is strictly function over fashion, I flared it from 2.5" to 3" right after it clear the AC compressor after the firs bend off of the turbine housing... agian, $30 home depot welder, boring ass sunday and a shitload of piping laying around can turn you into a freak like me... https://honda-tech.com/forums/images...s/emsmilep.gif stan What do you think of my wannabe setup? Should i just do 3" all the way through? i just bought a 2.5" flex pipe from RRE too. |
how long do you think that paint will last on the mani, snail, and downpipe???
what kinda paint is it?? |
Re: Not another 2.5-3" downpipe pic (DIY_Racing)
how long do you think that paint will last on the mani, snail, and downpipe??? what kinda paint is it?? |
I used VHT 1500 deg temp paint on the manifold and turbine housing, it's still there...
and when are you coming to tucson again at 4:00am to help me do mine? https://honda-tech.com/forums/images...s/emsmilep.gif What do you think of my wannabe setup? Should i just do 3" all the way through? i just bought a 2.5" flex pipe from RRE too. I used 2.5" from the turbo, then as soon as it clears AC compressor about 3" form the turbo, I flared it to 3" all the way back... stan |
Philo: where and how much did u get your 3" flex pipe?
I like it...looks like a weld made peice https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Not another 2.5-3" downpipe pic (ninesecrx)
Re: Not another 2.5-3" downpipe pic (TurboDANDEE)
the 3" flex piece is from jcwhitney.com and is ~$60
GB GB GB GB GB, want in...hook it up https://honda-tech.com/forums/images...s/emsmilep.gif
